Yeah I had a design that was basically a shrunken massdrop version that was floating out there.
I didn’t get a chance to print it out as I had to move my printer and I had no interest in leveling it again and getting print ready.
There’s no official thread for a lot of these DACs. I think I only see the Topping D10.
Should have one for the SMSL M100 too, at least, because Zeos really liked it:
And the Khadas Tone Board:
Done
Also not mentioned here I think, the Behringer UCA202 is… 100dB+ SNR for like 30$?!
(Not the UCA222 though, the UCA222 is worse than motherboard sound for whatever reason.)
I’ve heard it and it’s pretty decent. I don’t think it really its as good of the topping d10, but it is pretty good
Literally forgot I had one… plugging it into my Atom right now. ![]()
You know you’re an audiophile when…
Man this thing sounds clean. I was about to maybe buy a SMSL M100 but… Would it even sound better in a blind test?
The UCA202 only does 48khz though.
Honestly I would just hold off and wait tbh. I think a proper upgrade might be a su8 or d50s if you wanted a significant upgrade
Well, fuck me. TIL the cleanest DAC I had for years was a 30$ DAC I had left in my box of things to sell. Lol.
Loo, well now you know lol. Is it cleaner than what you were using up until you remembered that you had it?
Everything is cleaner than double-amping an AVR. ![]()
(I bought the Atom for my studio, not for here. – The recording interface will be its home.)
What about the Xduoo XD-05?
Probably not as clean as D50S / SU-8?
The xd-05 is good, but I mean that’s more of a portable combo and not really dac focused, but it does preform well as a dac through it’s line out. I do think that an ifi idsd nano bl would be good to use as a dac if you wanted something a bit warmer and smooth
I would use the XD-05 as a DAC, it looks so much like a desktop DAC lol.
As a bonus it’s still a 500mW yeet cannon so I could just walk around with my T50RPs
(And people would call the bomb squad)
I mean it would do a good job for that, but if you really don’t plan to take it off of the desk I don’t know if I would say it was worthwhile, because at that point I think the topping d10 might outperform or equal it
Thanks again for all your help @M0N ![]()
People already think I have speakers on me when I hook up my K550 up to my Little Bear B4 and lay them flat XD
i was going to try this thing out just for the hell of it for $13
If you can find a used Behringer UCA-202, that’s the best. 100dB+ SINAD for like 30$, praised by NwAvGuy a looong time ago.
