šŸ”¶ Audeze LCD-2 Fazored
From what I understand the pre-fazor = the classic, and that given my preference for classical music I’d be happiest with the standard 2, which is the fazor.
I’m not chasing anything…truth is that my mid-fi cans + the Asgard = terrific sound. It’s really just curiosity. What does roughly $1k get me?
The 2 F of course. I have heard it and it was quite good but not exactly the same… There are more knowledgeable people here that have owned that one
Have not heard the prefazor, but have owned the 2 Fazor. The prefazor is not the same as the classic, though, despite the classic being fazorless. Prefazor is said to have a little thicker low end and is a bit smoother than the Fazor, which trades some smoothness for more precise imaging. The fazors also make for a somewhat tighter stage and a treble peak, I think around 10kHz, gives a sense of teetering on the edge of aggressive at times. Swapping to suede pads can tame that a bit and make for a bit more mellow and laid back tone. I’ve only just moved on because I picked up the LCD-24, which I’ve heard inherited the tuning of the 2 prefazor and technical ability of the 4 (hence 24).
I’d also say, regardless of which version LCD you choose, coming from the cans you have will likely require a bit of adjustment to get used to the differences especially in the bass region. In the Senn line, I only have the 58x, but do also have the 880 600ohm, and LCD bass by comparison may feel a bit heavy initially.
I don’t think they necessarily replace either, depending on what you’re listening to, but I do find that I don’t reach for the 58x or 880 that frequently.
