I personally use the 145s in some cases as well but same problem, they seem to be on their way to accompany the dodo.
This checks the boxes for tonight’s listening :+1:
The Knife :+1:
The SpinFit Neo is identical in dimension ( at least for small & medium ), so the sizes are the same. The silicone is very close to the CP100+, but maybe a bit more tacky. In a comparison on using the Ziigaat Odyssey, I think the seal was the same or a little better, but with the exact same fit. I experimented doing each ear in a different tip, and it felt the same.
The biggest change is the color coding, and it seems like the Neo are all a slate blue, and the larger size of less transparent, so the smalls are a very light blue.
Thanks for the info.Finding the old yellow yellow core L/XL was getting really hard
For comparison these are the Spinfit Neo. The top pair are medium, the lower are small. The color difference is pretty subtle.
I remember Spinfits having a bit better looking stems than these..brown ish color lol.
Like these.
The color is more of a slate blue, but the smaller sizes get progressively more pale, so the color is pretty weak.
The CP100+ was also a transparent color, but with the small being a pink, medium were red, yellow for large, and I think the XL were teal.
