that isn’t what bias means, the sonomas run at a different voltage from pro bias stax and normal bias stax, they aren’t interchangeable, it’s like trying to run HE1 off a 353x or an ESL
You can change the voltage bias on the iesl pro
The sonoma M1 runs at 1350V, the iESL has a max output of 640V
Wow yeah. That wont work with my planned rig at all. lol.
Ya know, besides all the modding and stuff you would have had to do anyway lol. On my iesl I am running some sr007mk2’s and it’s great, no problems whatsoever
M1 = 4000$ and aperio = 24000$ wow ![]()
is there any difference between the L700 and the L700 mk2?
Slightly different build and tuning, and detach cables
does the tuning make that much of a difference? which one was zeos talking about?
Not really that much, if you can I would go for the mk2 just for the slightly better build
I don’t know what video you are talking about
sorry, this one:
Those are mk1 I think that came out awhile ago
Yep, definitely first gen. I haven’t heard / read anything about the build quality on the Mk II’s going up, I thought it was only a revision to add detachable cables.
Very slight changes, the plastic is less creaky lol
Detachable cables + metal yolks
The metal yolks helps with the seal which supposedly helps with bass
I didn’t notice a big difference with the bass but the yolks make it feel way more solid
