CVJ brand What have you done with the Assassin?
Holy Fuck these CVJ Assassin don’t use a bone conduction driver it uses a bass Shaker like the ones you bolt onto your gaming seat. 4D Indeed, never heard or should I say never felt vibration out of a IEM this intense before!
Stage is insanely good on this set as well.
Oh what about the Modular cable and BOOM MIC somes with 3.5 SE & USBC.
There is a vent for the vibration Driver and does it ever.
Soon as I flicked that switch the effect was instantaneous.
On Music Mode no Vibration Driver On you get a Warm, Smooth, Thick, Bassy Laid back sound. Top end is relaxed but bass is up there.
On this setting the Assassin will not win any awards for Air and treble details.
Turn on Movie Mode and your ears are totally vibrating! Treble perks up as well.
Right now this is listed for $48 CDN that’s crazy!
This Tribrid with…
1 Dynamic Driver
1 Vibration Unit
1 BA.
I just found this on AliExpress:
C$86.86 | CVJ Assassin 1BA+1DD+1 vibration switch adjustable gaming e-sports in-ear typec hifi headphones konoka
https://a.aliexpress.com/_mspVYl5
Advanced AcousticWerkes Z02
Two Driver Hybrid. $154.00 usd
  • Sensitivity: 105dB
  • Impedance: 18Ohm
  • Frequency: 10Hz - 40kHz
  • 10mm Graphene Dynamic Driver.
  • Micro Planar Tweeter.
Thanks go out to fellow Canuck Audioholic Bennet Kelly for sharing the AAW Z02 with the group for listening, and review.
This is my first exposure to AAW, or, Advanced AcousticWerkes.
There is very little information about who they are on their website, so… other than that they are based in Singapore, specialize in Custom and Universal IEM’s for both musicians and audiophiles, I know little about the company.
The Z02 is AAW’s lowest priced, entry level offering at $154.00 usd.
:backhand_index_pointing_right:t2: Pros and Cons:
:blush: Clean simple resin shell design is smooth and refined, on the small side, and lightweight.
They are very comfortable in ear.
And in my larger ears I get a “just past mid point” insertion depth.
:blush: The supplied pure copper cable is supple, has quality fittings, and unobtrusive ear hooks that work.
No complaints here.
Choice of 3.5 or 4.4mm termination at checkout.
:blush: 10mm graphene driver is capable of deep sub bass rumble and impactful mid bass.
:blush: Micro planar is tight and crisp.
:pensive_face: Occasional planar shimmer.
:backhand_index_pointing_right:t2: My Journey:
One comment about AAW I have seen made a few times is that their IEM’s are tuned energetic and bright in the upper mids and treble range.
Being somewhat mids sensitive doesn’t help, but my ears, and the Z02 FR graph, would suggest those comments hold true for Z02.
I didn’t find the mids or treble energy to be excessive, but it was consistently very present, and, over riding, or “out pacing” the amount of bass to some degree.
I tried some Final E series narrow bore tips, and while they did enhance the bass, and, warm and soften the mids. The bass became a bit thick and less detailed, and the head stage narrowed and became less spacious.
An enjoyable listen, but it took away some of what I liked about the Z02. The very well managed bass, and spacious staging.
With wide bore tips back on the Z02, I rolled through my DAPs and found the neutral, somewhat relaxed, mids of the Astell and Kern Kann Max, paired extremely well, and also complimented my personal listening preferences nicely.
:backhand_index_pointing_right:t2: Equipment:
  • AAW Z02 IEM aged 100+ hours.
  • Astell & Kern Kann Max DAP, mid gain, 4.4mm out.
  • Stock pure copper cable terminated 4.4mm.
  • Dunu SS wide bore ear tips.
:backhand_index_pointing_right:t2: Sound:
The bass is true to the recorded source. The Z02 faithfully reproduces sub bass with a deep throated rumble, but remains well managed, stays in its place, and doesn’t overwhelm the head space.
This not an IEM for bass aficionados that crave an omnipresent bass presence.
Very clean definition between sub and mid bass.
Mid bass is tight and impactful. It also stays where it belongs. Just enough carry forward into the mids to add a touch of body and weight without interfering with clarity and detail.
The mids are forward and clear with very good micro and macro detail.
Technicals here are excellent and exhibit well defined individuality between instruments.
Male, and, female vocals also present forward and elevated in the head space, with a mostly accurate and natural tonality.
On occasion I do note a touch of lean on vocals that typically have a husky lilt to them.
The highs have excellent micro detail and ample air and sparkle.
The micro planar is well implemented and has the quick transients necessary to keep the upper end crisp and tight.
Perhaps a bit too quick.
Cymbals and high hat can sound “too tight” with the “sizzle” decaying too quickly. (This a nit-pick)
I also notice, at higher volume, a touch of planar sheen can be heard on some tracks.
Head stage is very good. Leaning more toward intimate than expansive.
The cleanliness and clarity of the mids provide for a spacious and open stage with excellent layering and separation providing accurate instrument and vocals placement.
:backhand_index_pointing_right:t2: Conclusion:
The Z02 took several lengthy listening sessions, and some dialing in of ear tips and source devices before I came to truly appreciate and enjoy what they have offer.
They are an energetic, detail and clarity focused IEM with enough musicality to keep them from being “clinical”.
To revise a recent phrase from fellow Canuck Audioholic Bennet Kelly, these are not an IEM that will draw you in and “wrap you in a warm blanket”, but, they will engage, energize, and hold your focus on the music.
After a session with these you may be tempted to head to a nightclub and keep the energy alive.
** AAW Z06 is in coming. Watch for the Canuck Audioholics thoughts on them in the coming weeks.
:headphone: My music sources:
Qobuz, and, FLAC and DSD files stored on the SD cards of my daps.
My music genre are primarily Rock, Blues, Jazz, Symphonic, Country, Rap, R&B, Pop, Electronic.
Enjoy your music :+1:t2:
Loved reading this; such a well-rounded and honest take! Sounds like the Z02 really rewards a bit of patience and gear matching. That description of the mids “outpacing” the bass had me nodding; it’s such a tricky balance to strike. Really curious—do you think the Z06 might aim to mellow out that upper energy a bit? Or lean even more into the detail-forward tuning? Either way, can’t wait to hear your impressions when it drops!
Kinera Imperial Verdandi review
Shoutout to the Canuck Audioholics Review Group & member [Kaye Dee] for allowing me the experience the Verdandi.
Kinera Imperial Verdandi – Musical All-Rounder
PREAMBLE:
Kinera and its house brands Celest and Queen of Audio have graced the audio community with a number of good sounding iems. The Imperial Verdandi inherits the parent following this trend and is priced at $1100 USD.
The driver compliment per side included one bone conduction driver, two Knowles Balanced Armatures, two Sonion EST drivers and one 6mm Dynamic Driver. Lots of tech in a small place may be worrisome for some, but Kinera has a track record of knowing how to expertly implement driver tech with expert skill and the Verdandi is a yet another showcase of this design prowess.
Tuning wise we have a mild V-shaped tuning that is very tastefully done. There is no overt exaggeration in sound which aids this iem in being the perfect companion to long listening sessions without fatigue. Not necessarily a technical beast, the Imperial Verdandi is still able to easily relay nuances in the music in a more natural and pleasing way.
Moderately easy to drive, the Imperial Verdandi definitely benefits from a more capable source. This allowed the BC driver to come alive as well as improving the general clarity throughout the frequency range.
SPECS:
2 Knowles BA + 2 Sonion EST + 1 DD + 1 Bone Conduction Driver
Impedance: 14 ohm
Sensitivity: 105 dB
Frequency Response: 20Hz-50kHz
BUILD AND FIT:
The Impreial Verdandi is a beautiful looking iem. Fit and finish are excellent with the multi-coloured foil inlays in the resin shells giving that extra pop. The high quality of manufacture is readily apparent when examining the iem from any angle.
The Imperial Verdandi is a larger iem with a prominent nozzle molded as part of the shell. As such fitment may be an issue for those with smaller ears. My recommendation is to go down a tip size to ensure a deep well sealed fit for the best sound.
I did not receive the entire retail packaging but did have the original cable. The Original cable is of good quality with decent haptics, but I found that the Imperial Verdandi did better with another third-party cable I had for testing.
SOUND:
Bass:
Bass is powerful, tight and clean even when digging deep, and it does go deep. There is a pleasing meatiness to the low end with very good snap and detail as well.
“Protection” by Massive Attack has rich driving bassline and the Imperial Verdandi managed to convey this with ease. The poise and control are clearly heard as well. Switching to “Circumstance” by Wayman Tisdale” was more of the same great sound with a nicely articulate bass. “Inside Stuff” again by Wayman Tisdale was more of the same goodness with a rich and cleanly presented low end with notable snap.
The Imperial Verdandi is not a “Basshead” iem in that the low end isn’t in your face at all times. This is instead musical and organic bass with excellent power delivery and a bone conductor implementation done right. Very good indeed!
Midrange:
The Kinera Imperial Verdandi offers a clean and open midrange that is more immediate than recessed. Lush and detailed is a good way to describe the midrange sonics. Layering and separation are very good leading to a spacious sound. If anything, I would say that the midrange is balanced in that nothing sticks out in that range crying for attention. Adding on to that, harshness is never an issue.
There is a warmth to the midrange and note weight is well portrayed. The Imperial Verdandi is also forgiving of tracks with less than stellar quality. “You can’t make a silk purse out of a sow’s ear” but at least through this iem these tracks can still be enjoyed.
Timbre is good and transients are relayed naturally with a sharp attack and smooth falloff. Dynamics are done very well feeling unrestrained and lifelike in scale.
The Imperial Verdandi is suited to long listening sessions and the midrange is a big part of why.
Treble:
The treble is fairly extended with nice crispness and air. Cymbal strikes reveal no overhang or extra shimmer, being more organic. Strings sound again lush, with commendable clarity and detail.
The treble tuning here really compliments the bass and midrange.
IMAGING AND SOUNDSTAGE:
The Kinera Imperial Verdandi offers a soundstage that is expansive with great layering and separation. This quality is maintained even with more complex tracks. Pleasing quantities of width, height and depth are there for the ears to take in. Imaging within that soundstage is solid.
CONCLUSION:
The Kinera Imperial Verdandi is an excellent iem. While it may not shine above everything else in one particular way or another, here the whole is greater than the sum of its parts. Except when critical listening music always present itself as whole and the Verdandi does present a pleasing and “mature” whole sound.
The Imperial Verdandi’s performance matches its premium design and looks. It is one of the few iem which is perfectly suited to extended listening sessions for those who treasure a more musical experience.
The Kinera Imperial Verdandi gets a solid recommendation.
Nice review King Nubian!
Here was my latest two this weekend
Hi im new to digital players looking at the Fiio m23 VS shanling m6 ultra what would be best for the same price.
As it happens, I’ve recently demoed both the M23 and the M6 Ultra. They are both great devices but have different sonic characteristics. The M23 is (at least to my ears) more tactile, even visceral in its representation, especially where the bass is concerned. The Ultra is warmer, more musical and has a wider soundstage than the M23. It also has great synergy with different IEMs. Both have a double tap to wake feature and run Android 10, which is more than enough for streaming audio. In the end, it depends on your preferences. FYI the Shanling H5 portable DAC/amp has the same chipset as the Ultra (and comes with a battery so won’t drain your phone or tablet) but is significantly cheaper. I haven’t been able to demo that one but it might be an alternative to the Ultra if you want to go down that road. Hope that helps!
My Favorite Flavor of Ziigaat
Ok tonight’s mail call is NF Acous new NA20 IEM and new one under the music series.
So I was having some fun and saw some potential for a killer V Basshead IEM.
I slapped on a 5mm 500 mesh filter on the nozzle and damn!
I playing this off the IBasso Audio DX340 with the very Analoge AMP14 and OH boy my ears are having a great time.
These are SO MUCH FUN!
Ears weren’t the only ones having a good time it seems :wink:
Another solid and unique hit from Kinera/QoA
BGVP PHANTOM
Snake Year Limited Edition
8 Driver Hybrid IEM $1149.00 usd
  • 2 qty Sonion EST
  • 1 qty Sonion Balanced Armature (2300 Series)
  • 1 qty Knowles Balanced Armature (RAD Series)
  • 2 qty Double DC+Graphene Dynamic Driver
  • 2 qty Sonion Bone Conduction Driver
:backhand_index_pointing_right:t2: Preamble:
Thanks go out to BGVP for providing the Phantom Snake Year Limited Edition IEM to the Canuck Audioholics for review purposes.
To Andrew at MusicTeck for advocating with BGVP on our behalf.
And to Tone Deaf Monk for making it all come together. :+1:t2::+1:t2:
I received only the IEMs, cable, and a very nice red leatherette carry case.
I can’t speak directly to the unboxing experienced, but the photos online confirm it’s very well presented and certainly appears commensurate with the price.
:blush: Beautiful, maple wood embedded, red resin shells. Medium sized but on the thick size. Nozzles are on the short side and have a large 6.2mm diameter. My fit depth is in the large, outer portion of my ear canal.
Overall fit is very good for me, I get a stable anchor and seal, and good outer ear contact for the bone conduction driver.
There could be fit challenges for some with smaller ears.
:blush: Very nice, high quality stock cable terminated 4.4mm. There isn’t much information provided on the cable, 4 strands, on the thick side, and it appears to be a copper/silver plated copper hybrid. Despite being thick it is fairly supple and has ear hooks that work well to help stabilize the IEM in ear.
:blush: The impressive mix of driver types are well tuned. Driver coherence and synergy is flawless.
:blush: Excellent staging.
:blush: Good technicals.
:pensive_face: Sonion bone conduction drivers have a subtle presence compared to competitors DD driver based BC drivers.
(Personal, and subjective)
:backhand_index_pointing_right:t2: My Journey.
I rolled through several of my DAPs and the Phantom sounded good on all of them, so they are not a source device fussy IEM.
They do respond to the individual personality of each source device. The differences are noticeable and individual personal preference will still determine the best pairing. But, nothing I own sounded bad, and all drove the Phantom effortlessly.
I choose the iBasso DX340 with the stock AMP 15 card in place.
The 2 Sonion Bone Conduction drivers are vented via a small hole on the inside face of the shell, directly targeting the auricle bone structure immediately behind the outer ear structure.
(This is similar in concept to FiR Audio’s Kinetic bass where the back of the dynamic driver is vented through the inner face of the shell).
The Phantom bone conductor driver targets sub to mid low frequencies. I find the BC effect on Phantom to be quite subtle compared to other bone conduction technologies I have experienced.
I don’t consider this a “bad” thing, all of the drivers are very well synchronized and the overall sound presentation, including bass, is excellent.
But if you are expecting a skull rattling BC bass experience, Phantom will fall short of your expectations.
:headphone: BGVP Phantom Snake Year Limited Edition IEM, aged 100 plus hours.
:headphone: iBasso DX340 DAP with stock AMP 15 module, low DAC gain, mid AMP gain, 4.4mm out.
:headphone: Stock cable.
:headphone: Dunu SS ear tips.
:headphone: Sound:
The FR graph would indicate the Phantom is bass shy, but remember, the bone conduction driver is positioned to fire directly at the outer ear via the small vent hole on the inside face of the shell. The coupler wouldn’t pick up the influence of the BC driver on the frequency curve.
(It is my understanding BC drivers don’t graph reliably in most cases anyway)
Sub bass can, and will, pull low with a deep rumble on tracks that call for it.
Mid bass provides very nice impact without being too quick to roll off.
The two Dynamic Drivers, and the Bone conduction driver assist, assures there is no shortage of bass here.
Bass does however stay in its place. Some warmth to the mids, but doesn’t overtake the entire head stage.
Very well done.
The mids have excellent energy without excess. They present forward and elevated in the head stage, but once again, well managed and immaculately presented.
Open and spacious with very good macro and micro detail.
Never a hint of harshness or sibilance, the mids make their presence known without crossing boundaries.
The plot remains the same in the treble region.
Excellent micro detail, lots of sparkle and air, zero sibilance. Well managed and presented.
Many IEM are now tuned so the upper mids carry the high end, while the treble is rolled off with a little peak to add some sparkle.
Not on Phantom, the treble region is fully represented in just the right amounts.
The head stage has very good width and height. I find depth to be average, fills the head, but not overly holographic.
Imaging and layering are very good. It is easy to accurately pinpoint individual instruments throughout the head space.
:backhand_index_pointing_right:t2: Final Thoughts:
The BGVP Phantom Snake Year Limited Edition was a challenge to review. Too often review sessions turned into “fully engaged in the drift” listening sessions.
I should have had this review wrapped a week ago.
No regrets.
The Phantom is for those would like music presented faithful to the recorded source without any particular frequency having dominance over another.
I would say it has a slight lilt toward the mids, but everything holds its own.
In a nutshell….
Plenty of everything, not too much of anything.
Is the Phantom worthy of its kilobuck price tag? ($1149.00 usd)
I put it up against the Gaudio TODI ($1500) and the phantom proves itself easily worthy of competing in this price range. (See below for brief summary)
We all have our convictions regarding reasonable pricing for audio gear, but the Phantom Snake Year sold out quickly on most retail sites. Which suggests many find it worthy.
I know I feel it is.
(At time of posting I noted MusicTeck has one unit left in stock)
:boxing_glove: BGVP Phantom Snake Year Limited Edition vs GAudio TODI.
These two IEM only share a few direct similarities. Both offer a double dynamic driver “isobaric” type configuration, both are in the $1000-1500 price range, and both are of quality construction.
Todi is a 4 driver configuration 2DD and 2 BA.
Phantom is an 8 driver configuration.
Adding 2 bone conduction and 2 EST drivers to the 2 DD and 2 BA count.
TODI and Phantom have very similar bass presentation, but Todi is less vibrant in the mids which results in the Todi sounding overall warmer and more bass prominent.
Todi is no slouch in mids detail retrieval, but presents less forward and elevated than the Phantom.
Despite not having EST drivers the Todi competes well against Phantom in the treble region. Slightly less micro detail retrieval, but very similar air and sparkle.
Staging is similar very good width and height and average depth.
Todi has a slight edge on spaciousness and imaging.
Overall, Todi is a bit warmer and relaxed presentation, but not lacking in detail.
Phantom is more prominent in mids presentation and detail.
Both offer a mostly balanced and enjoyable listening experience.
Excellent share on this set thank you for putting your critical listening ears on Krusty!
Always appreciate your view and taking the time to share with others.
Thanks TDM :+1:t2:
It’s an honour to be part of the Canuck Audioholics and have the opportunity to experience and review some incredible gear.
seems that audiophillia is a cross-species hobby xD
appreciate the detailed breakdown! lines up with a lot of impressions I’ve seen. Interesting note on the H5 too…didn’t realize it shared the same chipset. Might be a solid value pick if the synergy holds up. Definitely gives more to think about
New Dongle has showed up with the Shanling UP6
I glad to see Shanling didn’t cheap out and west with a quality ESS dac instead of Cirrus Logic like everyone else.
Ear Acoustics Silver Angel SPA Hi-End Ultra – Energetic Songstress
PREAMBLE:
EarAcoustics is a company that from the outside seems to have just jumped onto the scene out of nowhere. Nothing could be further from the truth as they are the reimagined TFZ company who have a history of producing quality earphones. Presently they offer not only three different lines of iems, but various cables and accessories as well.
The present iem product line includes the SPA, STA and PHX series of earphones, the latter designated “Stage IEM”. There are seven iems that make up the STA lineup and five that are included in the SPA releases. There are some major and not so major differences between lines including a dual driver layout in the STA lineup and the use of a single dynamic in the SPA earphones. All of the SPA iems use a single 11.4mm dynamic driver but as you move up that line the driver material is different. The less expensive “Pro: models employ a Graphene diaphragm while the “Hi-End” models are furnished with a driver made of Titanium Gold Ball. On top off all that the shell materials used varies at each price point including resin, zinc alloy and aviation grade aluminum.
If all of this seems confusing, imho it is more than it should be. This is my one criticism of this product release. There are just too many in the product lines released at once for most consumers to make an informed purchase decision unless they really dig for information. To add to all this, the tunings are different for each iem.
The redeeming thing through all of this is that the SPA Hi-End Ultra sounds wonderful. It is an iem that the more I listened to it the greater my involvement with the music. Here we have an iem rife with details yet still sounding musical not clinical. An iem with a bass that initially put me off, but with continued listening I came to appreciate greatly how it is presented. Tuning wise we have more neutral presentation with some moderate upper frequency upward tilt. The SPA Hi-End Ultra is a chameleon though and occasionally had me questioning my tuning description.
The SPA Hi-End Ultra is fairly easy to drive but is source and tip sensitive. The $190 USD SPA Hi-End Ultra can be resolving and as such driving it from a competent source is a must. I recommend pairing it with a slightly warmer yet revealing source to get the best performance. As for tips I tried a few and surprisingly settled on the stock medium sized wide bore tips. I almost never use stock tips but there ya go.
SPECS:
Model: SPA Hi End Ultra
Unit: 11.4mm Titanium Gold Ball Top+Silicon Crystal Edge Double sided Composite Diaphragm Double Magnetic Circuit Double Chamber Dynamic Coil Unit
Sensitivity: 110dB
Impedance: 26 ohms
Frequency response range: 5-40000Hz
Wire specification: 0.78MM dual pin oxygen free copper and silver-plated wire mixed weave 1.20M
BUILD AND FIT:
The Ear Acoustic Silver Angel SPA Hi-End Ultra is one beautiful IEM. From its shiny Zinc Alloy shell to its beautifully done Year of the Snake motif and company branding on the caps and writing on the shells themselves, this earphone really is a quality product. Seen was what looks like a vent integrated into each shell. Even that has some nice design flair to it. I don’t know whom Ear Acoustic uses to manufacture their iem but rarely have I encountered this exemplary build quality.
The retail packaging also follows suit reinforcing the quality nature of this product. The included accessories are of high quality including the attractive case. The cable has good haptics and even better looks. My only gripe is that at the time of this review I don’t believe a 4.4mm balanced option is available. I received the 3.5mm SE.
Ear Acoustic has done a stand-up job with both the quality manufacturing and the presentation of this product. From the retail presentation to the iems themselves, it all screams quality. Let’s now see how the SPA Hi-End Ultra actually sounds.
SOUND:
Bass:
Bass does go deep, is well controlled and with respect to energy reflects what’s in the track rather than being overemphasized. The low end is snappy with decent slam and an overall natural sound playback. This versatile bass presentation is well suited to acoustic music, house music or anything in between.
On “Angel” by Massive Attack the driving bassline was there as it should be with pleasant texturing and power yet with a great level of control. Likewise, for “Inertia Creeps” also by Massive Attack where the bass was present with power yet not overshadowing the rest of the track. “Ekuseni” by Caiiro is a wonderful house track with a thick thumping bassline. The SPA Hi-End Ultra was more than up to the task with a nice and meaty playback.
I then moved on to “He’s a Carioca” by Eden Atwood and was pleased to hear the rich texture of the double bass coming through clearly. Now on the “The Journey Home” by Kriz where the SPA Hi-End Ultra again represented itself well with beautiful clarity in the low end. I was also taken back by how the SPA Hi-End Ultra rendered the bass in “No Jive” by Dephazz with such a natural and organic playback. The low end did not bleed into the midrange as the mid-bass stayed in its place.
The SPA Hi-End Ultra is not a basshead iem, but one which a listener like myself who values musicality over everything else very much appreciates. Some clarity incoming folks. The SPA Hi-End Ultra does not lack bass. Let me be clear that the It has ample power when called for in a track, a natural delivery and is incredibly versatile. The low end has good pacing combined with a more organic delivery that I find alluring. With respect to speed, it was also proficient though not as fast as some balanced armature bass driver earphones I have heard but still better than most dynamic driver based iems I can remember in this price range and even above. Well done!
Midrange:
The SPA Hi-End Ultra has midrange that is clean and expressive with a good mix of micro and macro details. The midrange is more lively than laid back but in a very good way. All too often a lively midrange usually means harshness or some kind of overemphasis, but with the SPA Hi-End Ultra this isn’t the case. Vocals, both male and female, are more immediate than recessed with a level of clarity that is noteworthy.
The midrange is open and uncluttered sounding with an organic delivery. At times I also found myself hearing details in familiar tracks that had been hidden from my ears in a few recent iems I have listened to. Another thing I found myself doing often is unconsciously tapping my feet and nodding my head to the music. This iem really pulled me in and it was well appreciated.
Layering and separation were notable, the SPA Hi-End Ultra never sounding confined with that dreaded wall of sound effect. Listening to “Beautiful Lie” by Vick Lavander was refreshing as each element in this hyper busy track could be clearly heard in its own space.
Transients were handled admirably with fast attack and natural falloff. Timbre was also good. Listening to “Our Relationship” by Dephazz the sonics are natural with that additional feeling that you are hearing with great clarity absolutely everything.
There is a well managed pinna gain with no harshness. The SPA Hi-End Ultra is not the most forgiving iem I have heard for poor recordings though. It’s not the most unforgiving I have listened to, but it can be resolving which does make well recorded music even more enjoyable. Poorly recorded tracks can still sound fine, but the resolving nature of the SPA Hi-End Ultra really makes well recorded music a joy to listen to.
I found that the SPA Hi-End Ultra’s midrange made it easy for me to be pulled into the music. This is high praise enough imho. It has a midrange, like the bass, suited any genre of music I threw at it offering an open window into the music.
Treble:
The treble is fairly extended with ample air and sparkle. Listening to “Vanston Place 12am” by Ronny Jordan the treble playback had a nice crispness to it with a natural, not overdone shimmer. The treble here really opened up the expansiveness of this track and was a joy to listen to.
There is a level of refinement here that while being bested by the Oriolus Szalayi, several times the price of the SPA Hi-End Ultra btw, still was distinguished to these opinionated music lovers’ ears. As with the rest of the frequency range, an admirable level of control and detail retrieval was experienced.
The SPA Hi-End Ultra has on offer a moderately large soundstage with ample space around the instruments. Single dynamic driver equipped iems have a leg up on cohesiveness and in this regard this iem does not disappoint.
Imaging a solid with a lateral placement being beyond the ears with a nice sense of depth and height as well. Layering within that soundstage nicely done and contributed to the open sounding sonics.
CONCLUSION:
To these Opinionated Music Lovers’ ears, the SPA Hi-End Ultra is a fantastic iem. When listening to them I found a few interesting things that contributed to winning me over. Firstly, I found myself eagerly listening to whole albums where usually I would just cherry pick one or two tracks for my critical listening. I also found myself unconsciously tapping or moving my feet to the music. Time would also pass quickly leading to long listening sessions and sometime not enough sleep. :slight_smile:
This just points to how easily the SPA Hi-End Ultra allowed me to get lost in the music. As part of an extensive, maybe too extensive, lineup of quality iems from Ear Acoustic, the SPA Hi-End Ultra stands out in its price range and above as a true gem of a performer which suits my listening preferences well.
With fantastic looks and build quality combined with an immersive and detailed sound, the Ear Acoustics SPA Hi-End Ultra is a musical and expressive beast. It gets a definite recommendation.
That’s the kind of experience every IEM hopes to deliver, when you’re losing track of time and just vibing through full albums, you know it’s something special. Sounds like it really nails that sweet spot between technical performance and musical engagement. And the fact that it stands out even in a crowded lineup says a lot. Love hearing about gear that makes you feel the music like that. And it quite the looker!
Such a well-balanced and thoughtful review! Love how you described the SPA Hi-End Ultra as both musical and detailed—it really helped me understand the IEM’s character. Appreciate the honest take on its versatility too!
