Thank you so much. I really, really appreciate it.
I was looking at the Aeons, but I didn’t know if I should look at the closed one, or the open backs.
On open back, my “high standard” was the HD6XX, and the Monoprice 1060; figured have one dynamic and one planar; and that’s how it all got started. Then I added the HE4XX because it seemed like a good deal for a hifiman planar headphone. The problem is I never moved past that point, and I never got to appreciate anything beyond.
I’ve been eyeing getting a Sundara, specially now that my wife took my 1060s as her mains (she moved from wh-1000xm3 -turned off- to the 1060 on a k5 pro - even though I installed balanced cables…)
I know people talk about sound signatures. It looks like you have quite a few beyerdynamic. Do they all share the same sound signature with small tonal changes? or is it more about adding sound stage or making them more recessed or a little more analytical?
Yeah I am excited about the Pandas, I think I’ll be able to use them in the office and with the mic maybe I can even use those for some streaming. I think I’m going through that period of being at home for so long that I start focusing on an idea and go full throttle. Just got the Monoprice MM-5R, the MM-3, the Monolith THX Amp/Dac all within the past couple weeks. I have remodeled my office so I sort of took that excuse to rebuild the “entire” set up, including the streaming room that I haven’t even used in years lol.
I was curious about the Elegia, but I’m seeing some talking about a dip on the 100-200 Hz that can feel as a roll off depending on the music, and that the highs are forward. Are they forward to the point of fatiguing/too sharp?
sometimes I just like relaxing with some music, other times I’d rather get enveloped in sound while I work, and other times I want as much detail as possible.
Looks like you have all the options out there.
Thank you again. I’m going to price out some headphones and see if anybody else brings up any suggestions.
Do you have any tube amps? do they make a difference for headphones? do they always make headphones sound warmer? or does it totally depend on the tubes? I don’t think I’d be using tubes for the streaming and/or gaming, but mostly if I decide to listen to some music for pure enjoyment. I think most of the amps or dac/amps I have are neutral or more analytical and not that warm, but I have little to no clue lol.
Also, thank you for the links. I’m checking them out right now. I think the headphone guide I have checked it out before, but I will review now that my interests have changed!
Thanks again!
