Do Audeze iSINE10 Need Breakin?
Holy COW! Those things will BOOM your ears off! Bass is WILD! Gads I wish I knew about this 3 years when I bought these things! Thanks guys!!!
One more question. What size tips do I need ?
I’ve stretched dekoni ear tips on mine and I do suggest trying foam but we really can’t tell you what size will work for your ears.
Just keep in mind that tips do affect the sound, I think is a little hard to find tips for them because the bore is wider than normal iems, so selection is a little bit tricky. Also they are design not to stick deep in the ear, they supposed to just sit on the ear, they are not meant to have a tight seal as regular iems.
I have foam tips on the Audeze but they’re to big for my ears ans start hurting after about an hour. The Audeze site has silicone tips I’m going to get.
Get the accessory kit that has the earwings, hooks and tips. You can definitely get them to have all day comfort finding a combo that works.
Yeah I saw that. thanks!
