Lmao the “disable” button is grayed out on the M300 for google play services.
I’ll just run wit Spotify I guess - the interface is ass tho.
hmmm try the first 2 methods here.
otherwise try this.
(i would probably not set it to none like they do but try 1 or 2.)
Well, in a weird turn of events, the disable option for the Google services was available. Thank you! I wonder if it’ll run a bit smoother now; we shall see.
Thanks, Riku. you da man.
Nice!
I would also try it with that trick in the link above. Doing both should be a massive performance boost at no cost for you and even help with battery life.
Absolute legend - I haven’t had an Android phone in about 9 years, so I totally forgot about developer settings. Good shout.
Still can’t sign in to Apple Music, but at least Spotify works!
I’ve picked up two more sets with 1 being a set I just listened to for the first time just a few days ago:
The Pure is old but I reckon gold. My EDC neutral-ish style set.
The Que is just going to be my benchmark for technicalities under $500. It has a very unique style Of tuning that doesn’t quite belong in any one particular group.
It’s warm, and slightly bright. Neutral but also colored. Vocal forward but not shouty. The bass graphs polite, but thumps in ear.
Strange IEM. I love it!
I bought the Que after having heard it at CanJam London 2026. To me, it’s a fantastic IEM period. I even bought the limited edition Merqury that has the same tuning but a different finish that matches (IMO) the sonic performance. Welcome to the club Dom ![]()
Thanks, bud. I got to try the Mercury version just a week ago and was thoroughly impressed. Loved the sound. I also loved the stock cable… too bad the regular Que has such a lackluster cable, but this can be rectified!
I got the Que with the upgrade cable because the first batch Elise had literally went faster than I could click on ‘order’. The only one left was one with a 3.5 and, not wanting to wait for an indefinite period of time, I got the upgrade cable as well. It is actually stiffer than you’d think. The Merqury cable (I’m guessing the ‘q’ is a nod to the Que) is better in that regard but you’d expect that for the premium you pay. Yu9 is working on a new model and I am hoping they’ll be able to keep up what they started with the Que.
I did see that they were working on a new model. Probably just in time for CJ NYC in terms of release. Get lots of ears on it all at once. They should do well, considering how warmly the community has reacted to the Que.
Blessed and fortunate does not begin to describe how I feel tonight. Insane lineup.
Courtesy of a very good audio buddy. ![]()
I got some quick listening impressions done today during some downtime at work. No distractions, quiet environment. M33 with FLAC files.
I don’t think anyone wants me to drone on. Long story short, I prefer the playback coming out of the Seraphim on most days, including today. It’s warmer, with a thicker low end that has more grunt & weight w/ lingering lows without completely destroying the mids. In fact, even though the mid-range is undoubtedly more pushed back compared to the Que, I find it a bit more ‘realistic’.
I think the treble is more refined on the Que, with a bit more air and a pleasing sparkle, but the Sera is less fatiguing overall at a simialr volume level.
Bass - Seraphim. There’s just more of it. It has a slower decay with longer trails to the notes and bass kicks.
Mids - Seraphim. Warmer, more pulled back and less in my face. Better depth as well. I prefer the timbre.
Treble - Que. More sparkle and air. It sounds more refined; it has a taste of a kilobuck IEM in there.
Techs - Que appears more detailed initially, but that’s just because of the treble tuning. Depending on the HRTF, with less masking, the Seraphim could sound just as resolving. The Que can come off as a touch glare-y to my ears, causing some nasty masking, thus hiding some details. For me, I enjoy the layering and stage depth of the Seraphim, but the Que has a wider sense of stage with better detail retrieval to my ears, albeit a little too forward at times.
The Seraphim is more comfortable to me.
The Seraphim is also quite a bit cheaper.
I have been reaching for the Que more than any other IEM I have; there is a certain… flare to its sound that is intoxicating. The treble is to blame, I reckon. It’s the special part of the IEM. But when I want a little more of a laid-back sound, with a thicker low end and genuinely some of my favorite female vocals I’ve heard under $1000, I reach for the Seraphim.
This is one of the great but also complicating parts of the hobby. To me, the Que’s bass and mids sound like you describe the Seraphim’s but I take that as a sign how important inner ear anatomy is (the real subjective factor in a sense). It is also tip dependent of course. If you happen to have them or come across them at some point, I’d suggest you try FiiO’s HS18 tips. There more straight bore than wide bore if that makes sense but, in my case, make the most of the Que’s sonic prowess.
That is fascinating…
What is even more fascinating to me at this point is the difference between my initial listening impressions at a Starbucks with a buddy of mine before I owned them, to now. Having them in house, tip rolling, getting the fit right, running through my entire library…
Thank you for sharing your impressions, it just goes to show, like you said, that HRTF is so incredibly important and it varies like crazy. I should say though that the Sera and Que do sound somewhat similar in a sense. Like, timberly and tonal wise, I find that they’re cut from the same cloth, just one side of the cloth is a different color.
I have those tips but I could never get them to fit. I’ll give them another shot, thanks, brother!
My pleasure! Isn’t that what forums and threads like this one are meant for after all? If I get the chance, I’ll give the Seraphim a listen.
Fun fact: i demoed the Que at CanJam using my BTR17, which I think you also have right?
If you hear the Que like I describe the Sera, then the Seras are going to be so warm for you. I’d be interested in seeing what you think.
Yes, sir. I do most of my listening on the M33 nowadays, but the BTR17 makes an appearance sometimes.
I’m interested in comparing them even more now. As soon as I get an opportunity, I’ll give them a go (unfortunately, Europe is still behind the US and Asia in terms of audio shows and events. I was looking into flights to London for next year’s CanJam but prices are out of control these days).
I have to be honest, I wasn’t even aware you were across the pond.
I do hope you get to hit up CJ, man. But I know how expensive travel can be. That’s the main reason why the farthest I’ve gone my entire life is NYC ![]()
