So Audionervousa hit me again and this time it resulted in me buying a new planar, the DSH Onyx. It started from a Jaytiss video where he reviewed them and I was intrigued with what he said about them. They seemed easy to EQ and rather cheap - Euro 530 ( $ 594) - compared to many other alternatives that I have looked at. Also convinced my selves that I missed that planar sound (whatever that is) so I ordered them.
DSH is a one man shop in Romania after he moved from Ukraine when the war broke out – its hard to drive a business when bombs are raining down every night.
Mine took two weeks to build and was delivered in a simple box in bubble wrap so don’t expect a fancy unboxing experience. The headphone themselves are another matter thou – large, well build and a solid as a tank. The build have a price and thats weight, about 600gr but they sit better and are more comfortable than my former Audezes I have owned. Clamp force and that big headband distribute the weight just fine so that I can wear them for many hours. They don’t feel heavy on my head.
DSH state the following data
Style: over-ear, opened-back
Premium leather for style and durability
Double-sided magnetic structure
Magnetic structure: proprietary magnet array
Magnet type: Neodymium N52
Transducer size: 100 mm
Maximum power handling: 5W RMS
Frequency response: 10Hz – 20kHz
THD: < 0.1% 100dB
Impedance: 25 ohms
Sensitivity: 98 dB/1mw (at Drum Reference Point)
The basic sound is crystal clear, resolved and spacious. Warm, surely not lean without EQ and more neutral with. All voices shine but without EQ female voices become a shade darker than in nature just so you know. To me they handle metal, pop or classical just right and I have been going through my catalog for many hours after I got them out of pure joy. It has taking me forever to write these words because I have been led astray into another track and another every time I have sat down to complete it.
Their best party trick are layering, separation of instrument and general head stage. The feeling is very alive, dynamic and natural if the recording permits it. Recording performed in real space with minimal miking are fantastic to listen to where its easy to pick up exactly were instruments and voices comes from. You know exactly how big the room is. You can follow individual musicians performances or every overdub not just the song as a whole if you want to. Your choice.
On the opposite end of sound quality its also clear that they don’t hide that fact but at least I can listen all of my crap sounding CD even if some are testing my patience to the limit.
A tone sweep shows that bass rolls off from about 40 Hz and that it has a soundstage dip between 1-2 kHz that so many brands use and that affect female voices a bit. Personally I have EQ the sub bass yo get deeper bass as well as some small adjustment at 800Hz and that 1-2 k area.
Mike
Wav files – EQ -Benchmark DAC3-Aune S17
