Can’t call it this, unless it sounds better than Timeless ;p
If you picked up the Dioko or are going to, I’d be interested in your thoughts.
Definitely passing haha. I want to see something going in the opposite direction of price(and performance, obv). Not the more affordable and weirder direction.
I’d recommend the seekreal airship since it pretty much does everything you need but better than the FD5 at $180. Haven’t heard the FH7 but you can’t go wrong with the airship’s tuning (and it’s alot cheaper).
Thanks for the rec. Watched a video on that set. Looks solid.
Pulled the trigger on the Raptgo Hook-X recently and been enjoying that very much.
Will add it to the list of DD considerations: KATO, IE600, AirShip, FD5, FD7.
I took the same route. Highly recommended!
Are you sure? Are you crazy?? Otherwise definitely FH7! ![]()
