You’ll want to replace the stock tubes in the Tuba, you don’t have to spend a ton, but the new production Mullards really do not do the amp justice.
There are several suggestions in this thread, I like the Tungsram, they can be expensive unless you roll the dice in EBay, the Ei’s are close and usually reasonable priced from reputable dealers.
Thanks man, will add that to the list…
I went all out and purchased a pair of Tungsram EL84 tubes. I also have RCA 7189 tubes, ei EL84 tubes, Soviet 6P14P-EV tubes, Sylvania 6BQ5 tubes, and Genalex N709/EL84 reissue tubes.
I can confidently recommend the RCA 7189, Tungsram EL84, ei EL84 and the Soviet 6P14P-EV tubes without reservation…all depends on what you’re willing to spend.
Those rca are really nice tubes but more of a pain to find, but if you can find them they are pretty great
right on thank you, my feeling is to maximize the experience, so ill def add these to the list
Now that you have your Bottlehead back up and running, any chance of a comparo with the Tuba?
I actually sold my Tuba to @j.fopps. But the quick takeaway is that the Tuba is a cleaner, less tubey sounding tube amp. The BHC is more traditional tubey sounding OTL. The Tuba is definitely more versatile having a low and high z output. The thing is, the only headphones I own that are not well driven on the BHC are the Elegia (which I currently am trying to sell) and the LCD-2 pre fazor. My DT880, HD650, Atticus and Aeolus all sound better on the BHC to my ears. Keep in mind that I prefer fun over neutral though.
I think I might be happier with a BHC than the MAD amp also. I don’t find it overly tubey. Soft, airy and clear and are not really what I look for.
I think the Vio has cemented my likes and has given me a framework going forward.
Sounds to me like we both have a similar sound signature preference. The nice thing about the BHC is that if for some reason you wanted a cleaner and airier sound, you can pop in a different tube. I personally do that when using my Atticus on the BHC. I have a Siemens E80CC (also referred to as a 6085 tube) that is detailed and more solid state sounding than the 12AU7 tubes.
I have collected quite a few tubes for my Bottlehead Crack. If you and others would like a write up on each tube I have, I was actually thinking of doing that as @M0N actually suggested it, which I agree is a cool idea. There is a lot of information one should learn before jumping into buying vintage or new old stock tubes, so sharing the knowledge I’ve acquired over the past few months sounds like a great idea.
It will have to wait just a bit as I have a 12AU7 to 6CG7 adapter slowly making it’s way to me from China. My buddy gifted me a Raytheon 6CG7 and a Tung Sol 6CG7, so I’m really looking forward to that adapter arriving.
Yes please.
I just posted my impressions in the Bottlehead Crack thread regarding power tubes (Since I have no more inbound and had enough time with them to form my opinions).
The Preamp tube impressions post will have to wait until my 12AU7 to 6CG7 adapter arrives.
Sure, the more knowledge the better. I was already buying tubes for my eventual delivery of my DarkVoice. Since that fell through I am selling the 6SN7 tubes as a batch.
I am going to hang on to the power tube in case I do go for a BHC down the road.
Looks beautiful!
How do you like your Tuba? I think it’s a great amp for the price. The wood looks great.
I love it. It’s a real fun amp to experiment with since it can drive low impedance headphones.
What tubes are you running? It took my awhile to find the “right ones” lol.
With the HD800S, I primarily use EI El84 tubes which can be purchased for $60; it’s a smooth warm leaning tube. At the moment I have stock tubes back in it because I found they paired better with some of my other headphones. You can find other recommendations up the thread.
What tubes did you end up settling on?
Nice job!! Its a really a very special amp!!
I tried several tubes the EI’s were my favorites.
Alex
