Haā¦me too. Asgard someday maybe.
I would consider the Sundara an upgrade to the DT 880 250ohm more than the 560 v2. All versions of the 560 is a warmer fuller sound compared to the 880 and Sundara. Itās a different style of sound compared to those two but the build quality is concerning. I am currently on my 4th pair and Iām at the point of accepting all 560ās have issues and the perfectly working pairs are rare. One of the two wooden ones had a dead driver in less than a day and the other had a severe channel imbalance. The two with the Sundara headband had perfect balance but lack the absurd authority in sub-bass the wooden versions had and sounded like the membrane slapped against something if the seal wasnāt air tight.
If you want to stay with a similar analytical type of sound and donāt want to gamble the Sundara would be a decent upgrade imo. Better separation, soundstage, bass, speed, extension, etc⦠None of that is really a night and day difference except maybe the bass. The Sundara has bass that goes deeper and is better textured. Everything else is just a slight difference here and there.
the only thing I really found better was in the bass. I liked the mids a lot more on the 880 as well as the highs felt smoother and more detailed but 880 seems to lack body and sub bass as well as it just doesnāt sound very āfullā. Can always swap out to the 600 ohm dt 880 for cheaper than the sundara which just sounds incredible. Less you want that speed and planar bass then yeah sundara is a good choice. Honestly just feels like two sides of the same coin with some slight differences
Would be more inclined to say this is just an issue with hifiman not so much the headphone itself. Quality control is a very well known big issue of theirs and its rather unfortunate.
I got the Sundara today. Iāve listened to them throughout the day. Hereās my mini early impressions:
Packaging: Great. Inspires confidence, unlike some other brands⦠![]()
Build:
They look great and feel better built than my 6XX. Weāll see how lucky Iām gonna be in the future, with so many people having quality complains with Hifiman. Fingers crossed.
Fit:
Theyāre not bad, actually. Weight is distributed nicely and pads are big and wrap my ears well.
Top band is alright. Could be a little softer, might be a good idea to add something there.
Itās early, so I expect things to soften up a little as I use them more and more. That said, they are not as comfy as my 6XX. The pads make me a little itchy (similarly to the Shure pads, interestingly).
Sound:
They sound great! If youāre considering them, I can tell you that you wonāt regret the purchase.
- in the first 5 minutes, I was like āthis is kinda the same as my 6XXā
- after some A/B testing and listening to more songs, I began noticing the āairierā feeling and wider sound-stage. Itās an interesting difference. Itās growing on me.
- initially the bass seemed similar to the 6XX. I think that the more I play these, the stronger it gets. Haha.
- overall, Iād say that they manage to represent bass well. If the song has it, itāll be there. If youāre a bass-head, youāll want to EQ.
- I like how the highs are there, but theyāre not piercing. I dig the sound signature a lot.
- Iām not sure yet, but it feels like I can hear more crap now. Like, imperfections in the recording or streaming quality. Will have to test a bit more.
If I had to sum up my experience so far, Iād say this:
The Sundara feel more⦠intense.
They request your attention, but donāt demand it (like beyers).
If the 6XX are the pair Iād wear to relax, the Sundara feel more like the pair Iād wear to get hyped.
That said, I do feel I need to point out that the differences are not dramatic.
If I had to keep only one, Iād be happy with either of these pairs.
Power:
Deception. HIFIMAN says they are mobile headphones. Yeah right. Well, I already expected this because of all the reviews, but these need at least as much juice as the 6XX. On my Hel, I use the same volume levels! High gain, 9-11, depending on the song. Most songs sound great 9-10, but some piano pieces I felt like pushing to 11 or more.
Playing music through the Apple USB-C dongle, volume is good, but I am playing too close to max. Itās the first time Iāve experienced what seemed like a slightly narrower stage due to lack of power, I think. But without a way to do really quick A/B tests, I canāt be sure. In any case, they are usable. Just not as good or loud.
Havenāt tried the BTR5 yet. But based on my 6XX experience, Iād say you want a balanced cable to push volume properly.
Openness (ie. outside noise):
-.- I thought the 6XX were open lol. These are like not there. Youāll hear everything.
Even when music is playing, unless youāre planning to go deaf.
Be prepared.
Find an empty room, or enjoy the down-mix in noisy environments, or buy something else.
Cable:
I almost forgot this. The cable is an abomination. I donāt understand why a company would create such a great product, then add this thing⦠It just has a mind of its own. Maybe time will tame it. More likely, Iām gonna create my own.
Other weirdness:
The 1/4" adapter was faulty. They sounded godawful with it. Channels would blend, sound-stage would collapse. Total disaster. Switched to another adapter I had, wonderful sound returned. Just FYI.
Conclusion:
So far, so good. Sound is great, comfort is alright, and the more I listen, the more I can hear the planar magnetic qualities.
Are they worth the extra $$ over the 6XX? Itās really hard to tell at this point. They do sound different, and the law of diminishing returns applies. For a better opinion, ask me again in a couple of months, itās too early now ![]()
If I was only one of these today, Iād probably get the Sundara. But Iād really be happy with either of them.
Next Steps:
Excited to try these with the Loki / Magni 3+ combo I have on backorder. Iāll probably replace the cable as well. My Hart Audio order arrives tomorrow, but I didnāt get the dual 3.5mm one⦠I might make my own.
Thanks for reading!
Nice write up! Canāt wait to hear later on how you feel because after a week or so these really got good. And a month later I feel the imaging and soundstage got even better. Brain burn in? Hahaā¦and keep in mind you can throw even more power at these with the asgard3. Really great amp with these.
Spot on⦠this is how I feel also between the two. I agree with @Bmn1251 give the Sundara some burn in time.
I also agree, they do get better as they loosen up, especially bass and soundstage. Work well with my Atom at 10 to 11:30.
So is the Asgard 3 a small or big improvement for the Sundaraā¦been considering.
Yes, big improvement from the atom to the asgard3. Thats what I did hahah
Dang. Figured that. In what regard better? Depth, SS? etc.
I feel it brings just about everything up. Maybe midrange is the same and the treble is smoothed. Better bass. Better ss.
Thanks, very helpful (except for my wallet!!)
@Bmn1251 how about the erish vs asgard?
Erish for a more wide,balanced, analytical sound. And Asgard for a more smooth fun sound.
Nice write up. I just put mine back on today after trying out a new headphone for a week. So comfortable and I really enjoy the sound. Funny to me that you say intense. I find the Elexās intense, but I find these very relaxing.
They are definitely my most power hungry headphones, but not a problem at all.
Welcome to the club!
Thanks! Brain burn-in, I believe in it
Iāll follow up in a month, set a reminder on your post.
Yeah, many people seem to agree that burn-in helps with these.
Iām curious to see how sounds changes for me over time.
I donāt know where truth ends and fiction begins, but the 6XX did sound better to me over time.
But, not sure if sound changed, or I got used to it. I also wonder if the pads softened and altered sound a bit.
I expect the Magni 3+ to be more than enough, no?
Itās like more than double the power compared to my Hel!
Would the Asguard 3 really make that much of a difference?
Well. āIntenseā is relative. I was comparing them to the 6XX. Perhaps āexcitingā is a better word.
If I were to compare them to the 770s, they are definitely not intense ![]()
Thanks!
I always forget how much power the magni has lol but i havenāt used it. I went from an atom to an asgard3 and noticed it got better. The a3 does give it some warmth however and i donāt know the magni does that. I think for $100 amps, the liquid spark is more recommended for the sundara, not that the magni would be bad for them. So maybe the magni falls in between atom and a3? Sundaras still sounded great on the atom, a3 just felt like a step up. So im sure you will be happy with the magni.
its all preference and what your willing to spend.
I set my self up with the a3,Erish, and darkvoice so i can hammer out some headphones with 3 different amp options
Hel is 1W @32, Magni 3+ is 2.4W @32, Asgard 3 is 3.5W @32.
I suspect 2.4W will be enough
Maybe a Tube next?
A tube amp with your 6xx will really make a difference, i only listen to mine on the dark voice. but no tubes for the sundara!
I think the Magni 3+ is going to be much better for the sundara imo⦠the LS is a fantastic amp but the sundara will benefit greatly from the added power the Magniās have
the asgard 3 is a very nice amp and highly recommended pairing for the sundara but coming from your current amps you will hear a nice improvement and in the $100 range I think you choosing the 3+ is the perfect option imo ![]()
Thatās where Iām at next. Deciding on which tube to get. ![]()
