Guess im resigned to 96/24 using a minidsp. Parasound any good they got a $400 amp with high pass but it only does 40HZ.
Sorry for hijacking.
For PA in a medium sized venue, no.
At home for anything except passive subs, horrible.
The JC amps are good. The rest are average imo.
sorry i have been busy, if you use a 12mF coil with your 800uF capacitor, should give you a 51hz second order low pass.
edit: also if you increase the mF of the coil higher, you will lower the xover point more. alternately, if you reduce the value you will lower it. if you want to get a few different ones to test off of the same cap.
11 mF coil will give you like 57hz low pass for example
