Wireless can be really good if your phone and ear buds match with the codec they support. The issue is they run on tiny batteries, so equalizing them with a preamp reduction is a problem. Every decibel you reduce it, needs 29% more power to avoid distortion. It just adds up to where you don’t have enough volume.
Best compromise is checking response charts to get a pair that’s as close to what you want out of the box, or just requires reductions, not boosting anything.
Not close. There are $50 IEMs with better sound quality than Apple AirPods Pro 2, and the APP2 is widely regarded as the best-sounding set of AirPods.
That said, I use my AirPods almost daily for calls and podcasts. Love them. Just not that great for music.
I know there are TWS earphones that sound better than AirPods. But they’re expensive and don’t sound anything close to wired counterparts at the same price, IMO.
I didn’t have any example of out of the box great sounding TWS IEM.
The best results in terms of sound i got from Fiio FW5, but:
Only with PEQ (thankfully they have lagre power reserve).
Ergonomics is meh
No ANC
Software glitches that caused frequent necessity reset TWS to defaults and rebuild EQ profile.
Even though I could make them sound amazing, UX lead me to use more stable and feature-rich solutions from mainstream brands. it’s harder to PEQ them imo, so i never got the “endgame” sound, rather acceptable one)
It really comes down to convenience VS sound quality. If you can, having both is a pretty good option — TWS for when you’re out and about, and wired IEMs for when you just want to sit back and enjoy the music at home.
