How to listen to FLAC
For Bluetooth I don’t know tbh, never bothered with Bluetooth
I would have to assume it dosent anyways. Thnx!
UAPP works with BT just fine and then again wired with otg cable - no changes need to be made
in wired mode it´s of course this player only with an external dac - no switching between UAPP and Youtube or spotifyy for example
at least you can play your own files and switch in the app to Tidal, Qobuz, Google Music, your network or DLNA setups
Use the app with Samsung Galaxy S8+ and S10 and ifi xDSD, ES 100 or Fiio BTR 3
I have been using USB Audio Player PRO for a while now and it’s an excellent all-round player. Good sound over USB, BT or just the headphone jack.
I figured out a trick where I can use Plex to sync a playlist of FLAC files to the SD card on my phone. Then I point UAPP to my SD card to scan the storage and create a library for playback. All the syncing happens in the background whenever I modify my playlist so I never have to manually copy/delete files from my phone.
