Nvm just get the Kasier, literally fixes the issue I have with it, less fatiguing but still smooth, vocal more powerful and detailed, and more sub-bass rumble
and it’s $129
Tanchjim really cooked with this one
How is it for a 6mm dd, better than the others at that size you tried? Thats the main thing i see with this release, a tech showcase showing off how far they can push such a limitted setup.
I’d still take a single 10mm full-range or any other combination over a single 6mm full range. I think the 6mms are good for bass only like an isobaric setup, or treble only as a tweeter, the miracle one’s bass lacks the impact/slam vs a bigger DD and that drawn out decay in the driver since it’s very quick and tight. It lacks the low-end dynamics is another way to put it. When you compare it outside a vacuum of just single DDs the Kasier for example has better midrange clarity, and low-end impact, but still maintaining the treble quality (and $70 cheaper).
It’s interesting, but it doesn’t make sense at $200 since I think the point of this is to show that a cheaper single DD can match a hybrid or mutli-driver iem that usually costs more in theory, so at $100 or lower this would be a good rec, but $200 feels like they’re just recouping their R&D cost lol. If you can get it for around the same price as Kasier you should go for it… but I’ve been seeing people grabbing the Kasier for like $80 with coupons sooo
That is exactly what I meant, 6mm dd is too small and way too much of a bottleneck for a single full range config. My question is how it fares against other single 6mm DD configs.
Havent heard much so not too sure, most of them are used with other drivers. vs 10mm the air does seem smoother/better
Smaller will usually have a trade off with worse bass, they basically need a compensation boost similar to BAs to feel similar to more usual 10mm DD.
Jay posting IEM impressions on his thread… we are so back.
Peace GIFs | Tenor
@VIVIDICI_111 thanks for great review, Thanks guys for help — I’ve decided to drop the AFUL entirely. I have one more question for you: given that I already have the Xenns Tea Pro (for rock, pop, and club music) and the Xenns Top Pro (for more laid-back listening, with a focus on female vocals and instruments), is it worth buying the Xenns Tea Pro SE? Is it a significant enough upgrade to justify the $450 price tag?
Or does the tuning and timbre of the Tea Pro SE lean too close to the Top Pro?
SE leans closer to top pro, I’d go for the Avant or BMedia jade for around $350, more different, but tbh nothing will be an significant upgrade over the top pros until you go est
I’m not sure if an EST or planar implementation would be right for me. I prefer a detailed sound—but one that’s detailed without being sharp, sibilant, or harsh. I’ve listened to the Kiwi Ears x HBB Punch (1DD + 2BA + 2EST), and the treble wasn’t quite to my taste. I don’t want to take a step backward; if the Tea Pro SE performs similarly to the Top Pro, then there’s probably no point in switching. I’m hesitant to buy EST or planar IEMs without auditioning them first, given how significant the “color” (tonal character) of the sound can be.
If you want detail EST and planar is ideal, the one you tried was a basshead and not tuned for treble
The Hype 4MK2 is the only IEM i can think of around that price that is noticeably a step up in detail, but it’s bright in tonality and not as full in the low-end, up to you
I’m not looking for an all-rounder; I find the Top Pro to be highly detailed, so I don’t need to replace it. I’m more interested in an upgrade to the Tea Pro—for rock or pop, I prefer a warmer tonality with good note weight.I tend to listen at relatively low volumes, so sharp high frequencies bother me.
Could the Tea Pro SE serve as an upgrade to the original Tea?
Should I look for something else? Or does a change—with a budget of up to $450—not make much sense, and would it be better to just stick with the Tea Pro?
nah stick with tea pro
I’m keeping the Xenns, but I want to try something new; I’m considering the CKLVX x Soundcheck39 Hydra—there aren’t many reviews, but it’s said to have good bass and exceptional soundstage and imaging.
I’m not looking for a “mega” sound; rather, I want something musical, with good timbre, proper note weight, and smooth treble.
The PILGRIM 26 might just be the worst IEM of 2026
This is the packaging you’re getting at $300 - A FUCKING POUCH WORSE THAN THE $60 DUNU
Wel, pilgrims were modest people right? So this is a vicarious reproduction of the experience (or something like that :man_shrugging:)
hope you’re joking cuz this is a joke at $300
PILGRIM 26 impressions:
-thin, shrill, and shouty
-vocals have no weight and power behind them
-no bass, I feel like im getting tickled by the drums
-lower-mids are heavily scooped out
-male vocals are gone and feels way too light with no texture
-treble gets shrill and overwhelming
DUNU PRS5 impression:
-muddy, overly thick, congested
-no air, detail/texture is smoothed out poor transients
-bass and lower-mids feel bloated
-higher volume saves it a little but still lacks air/detail/resolution
-lowkey worse than the PRASS6
-not sure how this is a “gaming iem” when the layering and imaging is doodoo
Dunu Subsurge impressions:
-well balanced with fun rumbly/bouncy sub-bass
-smooth vocals with slight treble energy
-ok performance for the price while being smooth enough
-vocals are clear and non-peaky, but can come cross shouty
-overall decent all-rounder with good low-end dynamics with enough balance
-the $60 IEM is the best sounding out of the 3 I got today lmao (and yes I bought all 3)
