Like a TOPPING D10 DAC isn’t better than the K3? Is the K3 actually considered a good DAC?
The d10 would be an upgrade, but not a massive one over the k3, you would be getting an upgrade but it wouldn’t be the largest change
The D10 is on sale right now on Drop:
Would the D10 and Spark be the absolute best DAC and AMP I can get for $100 each (Specifically for the Sundara or Edition XX)? Also if you are asking why not just raise your budget for the DAC and AMP, it’s because I believe in a high dip off in price to performance the higher and more expensive you go. I can afford a $2000 headphone setup easily, I just know that the price to performance wouldn’t be there.
Because honestly I just threw the D10 out there randomly, there might be a better DAC for $100.
Depends on the headphones tbh, I agree the budget realm is best bang for buck though
Welp the new topping e30 is about 130$ it seems to be the best for around 100$ but the topping d10 is 77$ right now.
The topping e30 is mighty impressive for the features and sound it has for the price
I mean the topping e30 is not too far off a $100. and if you wanted the absolut best in general interms of measurable performance at a $100 the schiit heresy wins but in terms of pairing something warmer like the magni 3 + or the liquid spark is definitely the direction we want to go. pairings are based on the headphone your getting more than anything else
The Sundara is a nice point. I would say its beginning hifi tier. Its just about perfect in many ways. But theres still a nice portion of improvement into the 600$ range. theres where the Aiva clones and Elex reside. From their its more diminishing returns i think. Although the Sivga p2(aiva clone) is 400$
OK, So I am now going to get the Sundara’s (most likely) the Spark and the Topping E30. This was an expensive post to make.
Also sorry for all the back and forth’s, I am just trying to get the best of the best for the money.
sounds like a solid combo. and dont forget to try the he 4xx off that combo as well you may very well be pleasantly surprised.
Yes with more power the 4xx also improves
If anybody else has DAC or AMP recommendations for about $100 and Headphone recommendations for around $400 I am still open to hearing out any recommendations. But at this point without even looking at reviews and just going by how passionatley you guys are talking about the TOPPING E30 I feel like the only thing better than it would be way higher in price, Same with the Spark, but I might be wrong and probably am as I rely on other peoples recommendations. Thanks to all of you that have responded so far, I think all of you responded to my original post a year ago
I feel like for what you are after you should be set on the dac and amp front, and headphones it feels like a solid pick. One last question though, didn’t you have the sundara at some point already?
yes, but Hifiman emailed me later that mine were a defective pair.
Ah ok gotcha
So just to be sure though. Spark + E30 + Sundara’s (If I can’t get cheap Edition XX) is the best I can do for the price and for this specific combo? Also how much better would you say the Edition XX are over the Sundara’s because I plan to keep this settup for 5+ years.
They are different than the sundara but I do think they would be a good upgrade, more bass impact, better layering, very large presentation, pretty solid and comfy too imo. I think if you can go for it, it would be worthwhile imo
And what about the first part of that question?
