Why dont you pull a Zeos and just put a bit of clear coloured tape over the LED to change or mute the colour. Or, if you want a cleaner look, you can always colour over it with a bit of marker.
I was kinda of thinking the same thing tbh. If you really wanted to, you could just open it up and remove the led if it bothers you that much
The topping pa3 could possibly work for you as well
Oof. Perhaps try black electricians tape? That’s what I use on my monitor because when it’s in standby it blinks blue, and I just used electricians tape to cover it up
Does that work well? It works fine in my case, but I didn’t have a flashlight level led
Yeah it works well enough, but I kind of just leave it there because I’m too lazy to remove them because I broke the LEDs a few months back when I was trying to see if I could install a few new buttons for custom integrated bias lighting.
