Tanya also has that godlike filters that do wonders on some IEMs. FH3 is one of them, according to a buddie. (Mine is on the box for sale so I won’t try it)
Yeah I’m taking the filters and tips, resell it for like 10-15 bucks
I will order it, it is cheap, I hope it is good …
huuuum gotta try it
Btw for micropore mod you use the tape on vents with DQ6?
Yes, taping the vents.
I need to try that mod on my E1000, see it it does anything
Could please share the link of the KZ-DQ6 mod?
I have no idea what foam mod they are talking about
Thank u
(link to that page is at the top of my thread)
Tape material makes a difference? I only have normal tape I think
Thsnk you
lol, yes it does.
Micropore has small pores that allows some breathability, while regular tape will seal it off completely (which means more bass quantity but at the loss of quality usually).
What micropore tape did you use? I have medical one.
Need to check an hardware store then! ty
ehm…I dont know?
I just bought one from a pharmacy.
This one.
