đŸ”¶ Sennheiser HD600
Depends on the recording
how well its mic’s. One mic, two mics, three mics etc
and then the mixing
I have many recordings with different cans that exhibit more than these “three blobs” you speak about
IMO there is so much crap recordings that often contribute to this “three blob” thing
as a critical listener I often skip over songs that are just “meh”
and gosh my standards lately are really very narrow focused. Once you here a really well done song
its hard to tolerate the meh" stuff
This is all tempered with my mood, time of day, and I hungry, is the coffee fresh, amount of alcohol consumed etc
LOL!
When I evaluate I tend to listen to stellar recordings - Chesky, Mapleshade, Doug Sax, Steven Wilson, etc.
My HE-6se v1 and HD-600 do not have good soundstages.
My modded HE-500 and HEX v2 for sure do.
The HD-600 on an OTL tube (overbuilt BHCs) has 5 distinct areas across the stage that are somewhat connected but not like a large regular rectangle you’d get from excellent speakers. These 5 areas much cleaner and more satisfying than the 3 blobs.
far left - intermediate - C E N T E R - intermediate - far right.
the drawback is that the intermediate area closest to CENTER is deeper than the CENTER plane, but the intermediate closest to far *** sticks out a bit from the main plane. Its a shift of maybe 15 degrees, its consistent on my BHCs. It is not that annoying, but a matter of interest.
What happens if all the band members are on the extreme left or right ?
Good question
 no idea.
Yes acoustics is a very interesting topic
Soooo many variables here
The physical venue, structure of the recording event is important and can influence the sound.
The placement of instruments, and band members is important and can influence the sound.
The placement of the recording microphones is important and can influence the sound.
The mixing of these mic inputs, the levels, eq’ing is important and can influence the sound.
The transfer and sampling (usually upwards), bit depth, algorithms is important and can influence the sound.
Then there is your stuff, pc, file format, downstream adjustments, the dac, amp, headphones and YOU.
YOU consists of your experiences, bias, likes and dislikes, mental state, shape of your ear canal etc.
What I am trying to say is when looking at the soundstage your experiencing with a set of headphones and even a normal stereo setup
the way the music was recorded, where the mics are, the people are etc can have a profound influence on your experience and conclusions.
If a band is mic’d poorly
(lack of experience or experimentation etc) these discovered issues can be attempted to correct to some degree via level controls in the mixing console. Better to re-do the mic placement to get the “sound” you want vs trying to fix stuff that was done poorly in the first place.
So many things here can influence your thinking of how a set of headphones are reproducing stuff
Great topic!
It was a kit that was never built for $350. I upgraded it a lot: caps, transistors, etc. about $450 more, have some nice tubes too for another $400. The other one I know is strictly stock. Mine is maybe 10% better.
I bought a hd600 to mmcx converter, you guys think ill lose much using some random cable from the tin t2’s i have? I really hate senn cables
try em n find out.
yeah I am and they sound fine so far, im wondering if anyone has done any measurements.
what kind of music are you listening to? that could have an effect on any possible influences the lighter weight cable is having.
ETYMOTIC er2se. Good upgrade
 basically a n earplug hd600
Hi Guys I Need your help.
I have to purchase an Headphone Amplifier to pair HD600.
I have decide if Going for a model with XLR output or NOT.
HD600 with a FULL balanced Setup Is Better than SE setup?
No. It will probably be able to go louder (maybe depending on the exact configuration of the amp, but this would be normal).
My choice Is Lake People G111 but There are no XLR output.
It has only XLR input.
I can use HD600 only in unbalanced configuration even of I Have a DAC with XLR output.
Sennheiser HD600 vs HD660s vs HD650 which headphones are best for you?
