Final tuning?
Channel in the nozzle wall itself? Is that for a single vent, or the four of them?
I removed the 2 nozzle vents, there are still the 4 main chamber vents. This vent is AFTER the nozzle damper, which makes it very unique. I had this idea last year and decided to try it after noticing both the new Sony BT and Final Audio are using the feature. Should have done it earlier! It makes the treble extend extremely good for a DD.
Back wave reflections can escape with the quickness! As you can probably see, i’ve been optimizing the treble replay, all the while balancing the lows.
The tip itself creates the nozzle vent.
That channel is not in the nozzle wall itself at all, its a valley/canyon around it, the nozzle is still solid af
This is definitely the least about of body noise/occlusion effect ive ever heard. Good shit!
lol about size
size difference is actually hilarious
Size doesn’t matter right :wink: Graph-wise, is the red one the Storm or the Anomaly?
Red is storm
Thanks! That helps.
Here is my Storm review if anyone is curious. What a cool iem!
Time to sell a kidney I guess :wink:
4x 1.0mm vents in main chamber. 0.3mm x 4.6mm channel/vent AFTER the end-nozzle damper.
Rubber oring seal, spring pushing driver into oring.
the way this thing goes from mild mannered to WHAT THE FUCK is insane
It is complete??
I think so. Im working on super fine details. Actually having an issue 3D printing when I break off the supports they create little dimples that requires too much sanding to remove.. Gotta figure that out. The sound is great though.
Paint a very thin layer of resin and cure em, and then sand down. Start 500 grit and go higher till finish.
Avoid supports at the nozzle area (in the slicer, use the nozzle ring/tip as the base and lift up and add supports all over the shell, and supports on the nozzle ring) that way you don’t have supports on the nozzle body except the top which is easy sanding. Maybe have a eartip on the nozzle and then use that to hold and paint over the iem.
That is a great idea actually.
Here is how im doing the supports
The nozzle is easy to sand actually, its the front part of the shell that sucks
You’re already doing it the way I mentioned, Noice
The flat part that has the supports, that’s the only area that needs painting
Take a small paint brush
Take the 3d print resin in a bottle cap or dab it straight up from the resin tray and paint a thin layer over the flat area and cure for like a minute or two and then sand down.
You’ve got this!
I’ve learned that that question is best asked after he says something is complete over the years :grinning_face_with_smiling_eyes:
That blue neon lightshow with the black is pleasing my autistic brain.
That should work! Good deal.
