SIVGA QUE : Premium craftmanship meets vibrant sound!
SIVGA QUE
✧ ════ •REVIEW• ════ ✧
「SOUND-SIGNATURE」
A bright mild-V shaped sound. Punchy mid/upper bass with lively lower treble. Mid-range/vocals have good sense of engagement.
「BASS /LOW-END」
► The bassline sounds like is a mid/upper-bass oriented. The bass punch felt stronger with a quieter subline demeanour. It sounds fast, nimble and punchy.
► The sub-bass presence is on the polite side. The rumbling, tremoring and booming effect seems more a like background character than showcasing its dominance. They’re more heard than felt. It fades in and out at quite a fast pace. As a result, the sub-bass texture and vibration will come across flatter in nature and less atmospheric.
► Mid/upper-bass presentation is denser, thicker with wider sense of attack amplitude. It allows bass percussions components to have a good impactful replay.
► Kick-drums can sound sturdy and tidy at upper bass. At lower range, it can pack a softer punch.
► Drum-strike sound more consistent, it often leaves a good sense of tactility to the way it slams.
► Bass line guitar well played out. The rate of humming and droning is well distinct without bloat feel.
► Bass-drop is keep clean and clear. While ghetto bass have decent bouncy feel. There is no major bass bloat or mud as far as my ears could tell.
“Overall, its punchy bass nature still manages to keep listeners engaged. Despite, lacking in sub-bass presence, the overall bass quality is quite solid.”
「MID-RANGE /VOCAL」
► The mid-range/vocals were given good highlight in the mix. The vocal positioning can varies depending on where the voice lands. Regardless, the vocalist will stand slightly further versus the rest of the background elements.
► What impresses me the most is the clarity. Vocal texture such as breath, husk and grit has good level of transparency. They sounded crisp and clear.
► Tonally, it is on the bright side. The energetic upper mid-range is what makes vocal and instrument sounds alive. In terms weight and body, it is not the most consistent. Some part of the range does come across sounding thinner and leaner than others.
► MALE/LOW-PITCHED: It is not the warm, lush and thick type of presentation. But it’s got a natural fundamental weight and density behind the voice (from bass to tenor). The natural rise and fall to the voice is well depicted. The emotive essence of it often carries the flow of its performance.
► FEMALE/HIGH-PITCHED: To my ears, they both performs equally as rewarding. Their head-voice just sounds as powerful. The slight thinning effect do benefit those high-pitch vocals. The sense of breathiness or airiness is well highlighted. The vocal range is noticeable wide. There is no sense of roll-off when the vocalist tries to reach for peak. Even so, with shouted or screamy vocals, it handles them well without dampening them too much.
► Occasionally, there is slight emphasis of the Ts and Ss consonant on vocal transient Which happens more frequently with ACG, K/J-pop genres. At the very least, there is no unwanted vocal grain or sharpness
► Acoustic guitar sounds realistic. It has good balance of bite and note-weight.
► Piano plays is no different. Every tap is well distinct within the mix. None of that soft-rounded attack.
► Violin and cello sounds expressive, especially with bowed strikes.
“In short, the mid-range quite the performer. Its sounds engaging and resolute. It is not for people who seek warm, rich and laid-back sound.”
「TREBLE / HIGHS」
► The highs have this bright-neutral character to it. Whereas the lower half of the treble has a strong sense of brilliance but post that, it rolls off gradually. As a result, though, it is on the bright side, it not the airy, shimmering type of high-end. To many this will sound more correct.
► The peaks and troughs of the treble are there but in a good way. It creates a good sense of contrast with the treble elements without accentuating unwanted spikes or hotness at normal listening volume. However, I must say that sibilance control is not the most forgiving (especially at higher volume) but it is well within the means of tolerance. Meaning, it doesn’t pierce your eardrums.
► Treble definition is one the best in class. It is very impressive for the price. The attack is well defined without causing any sharpness or harshness. High notes often come by with a natural weight.
► Hi-hat have a good prominence in the mix. It has a clear “chick” even when hitting constantly. There is no fuzziness with its definition.
► Cymbals plays sounded smooth with subtle crisp texture. It exhibits a natural flowy quality as it washes away. It doesn’t sound splashy when it crashes which is just pleasant.
► Drum-snare have good clarity too. The “pops” and “cracks” doesn’t sound peaky with sturdy thud when is strike.
► Glockenspiel will have a softer ding with a more subtle overtone.
► Electric guitar has a fine blend of engagement and pleasantness to them. Guitar solos especially have a good focus in the mix without overshadowing lead vocals.
► Synthesizer and electronic zing, ring, buzz and the likes sound well define yet inoffensive.
► At louder volume, the inherit peaks will eventually get in the way. Treble sensitive folks will have to lower their volume for ease of listening. It can detect the signs of bad recording, but it doesn’t elevate them to an annoying degree.
“All and all, the treble performance is solid. It has good definition and sounds refine enough to carry most music library.”
✧ ════ • TECHNICAL PERFORMANCE & OTHERS ASPECT • ════ ✧
The STAGE DIMENSION is just average in earphone space. Its offers good width with believable sense of headroom and depth.
SPATIAL CUES is solid for the most part. The placement of music elements between two-channel is well laid-out with good level of accuracy and vividness.
INSTRUMENT SEPARATION; For single dynamic-driver, it is very good. Even on busier tracks, the vocals and instruments maintain its borders of sound well.
DETAILING-RETRIEVAL? It is one the most capable set-in price-point. It has good resolution across the spectrum.
It has a broad level of DYNAMIC-RANGE. The loud and soft elements well depicted. Such traits enhanced its musical elements.
TONE & TIMBRE? despite leaning on the bright side, it managed to keep things relatively natural.
DRIVER? The 10.0mm beryllium-platted dynamic-driver is a very potent driver. It doesn’t sound like cheap driver.
SYNERGY? It is quite easy to drive in general. It doesn’t need alot of power to become alive. If you ever find the lower treble to sound a little spicy, you should pair it with a warmer, darker source. Or else just stick with a neutral DAC/AMP.
✧ ════ •BUILD/ PACKAGING/COMFORT• ════ ✧
SIVGA never fail to impress me with its build quality. There is no budget segment that build remotely as premium as the Que. The coated metal shell combined with the wood faceplate makes its looks more expensive than what you paid for. Metal construction is suitable for smaller ears that is not too heavy to be worn on long sessions. There was no driver-flex nor pressure build-up issue.
Inside the box, there is brown leather-like casing for you to store the earphones. The white two-core stock cable only came in 3.5MM single-ended. It feels very premium to hold. There is two type of ear-tips (short and long stem) sizing from S to L. Sonically it sounds fine. But I’d recommend using Spinfit W1 with it. It improves separation level and bass attacks. All and all, a well thought out accessories.
→ CONCLUSION ←
The build already impresses when I first touched it. It goes further by performing well throughout my assessment. For the price Sivga is asking, it is a capable little earpiece. Sure, it is on the bright side. But once you get the right eartips and source pairing, it is such a potent set. It sounds technical, dynamic without compromising its naturalness all that much. If you’re looking for competent bright mild V-shaped sound for less than $100, do check out the Sivga Que.
SIVGA QUE
PRICE : PERFORMANCE [$69.90] : ★★★★⯪ (9.0/10)
BUILD & PACKAGING [BASED ON PRICE]: ★★★★★ (10/10)
COMFORT : ★★★★ (8.0/10)
PERSONAL ENJOYMENT (BIASED) : ★★★⯪ (7.0/10)
OVERALL : ★★★★⯪ ( 8.5/10)
1-2 ★ - Appalling! please avoid this
3-4 ★★ Subpar offering, there are better options out there!
5-6 ★★★ Decent with some caveats! Not a bad pick! (CONSIDER)
7-8 ★★★★ Not perfect but solid choice! This should be in your shortlist. A nice addition to your collection. (SHORTLIST) (RECOMMENDED)
9-10 ★★★★★ One the best in class! You should go right ahead & buy one! A must have! (BLIND WORTHY)
Pros:
- Well-textured, punchy Low-end
- Clear, engaging vocals.
- Good treble definition.
- Solid technical chops.
- Impressive build quality.
- Classy and comfy shell.
- Premium accessories.
- Good value.
Cons:
- Sub-bass roll-off.
- Not the fullest, richest sounding mid-range.
- Treble peaks will rise at higher volume.
Driver Configuration: 10MM Beryllium Coated Single Dynamic-Driver.
MSRP: $69.90
DISCLAIMER
~ This unit is sent by Sigva for a review.
~ Assessment took place after over 3 days of burn in for better sound stability.
~ Using stock cable and Spinfit W1 (M)
Shoutout to SIVGA for providing me the sample for a review..
Thanks for reading!╮(╯▽╰)╭
