I have been meaning to update this for a while now. work has me constantly busy so I haven’t really had much time to actually sit down and finish the update…
I have this same issue with hd800S… honestly I love the clarity but really you get that much clarity from a lot of brighter headphones… 650 being the more neutral while 800s are very bright and peaky with a lot of clarity and detail not to mention the absolute massive soundstage that is potentially the largest on the market… the only alternative to hd800S I found was arya and I definitely preferred the Arya’s sound… not so much build on either of them unfortunately.
the problem with this is that, no headphone is going to be able to completely solve this for you. it takes time and practice to get a full grasp on being able to track footstep placement as it is… HD800S is one of the best you can even get for fps gaming out of all of the ones I tried it barely has rivals in that regard however, it’s imaging isn’t what I would call the best which could lead to some issues…
built like a tank with heavy comfort? that would be the T1 2nd generation which is what I use… the 2nd generation beyerdynamic T1 has a signature very similar to that of the HD800S yet better build, better comfort, less soundstage, but much better imaging… at the same time it still retains that beyer detail retrieval you can expect from the brand name… the 1990 would be alright too but it isn’t as similar in signature to hd800S
I suppose this depends on what you mean by in your face… because this could be soundstage intimacy or aggression of the sound. Intimacy of the soundstage would be like your old sennheisers you had before 800S and aggression is what 800S does as well as something like DT 1990… T1 unfortunately is not aggressive and very relaxed sounding.
I own both of those… clear is great for those who want a headphone that can fit pretty much anywhere but also prefer that more neutral approach to their sound signature… it’s quite an incredible headphone, granted not one I recommend personally for competitive but for music it’s absolutely fantastic and I use it regularly.
As for the 1990… since you can already tolerate 800s I think you will be fine with 1990s brightness… I think it’s worth a try if you can get your hands on one it sounds like the beyers are what your looking for in this case and they are no slouch in tarkov either seeing how I can place a sniper shots location with them just fine…
HD800S is a debatably a step above 1990 and T1.2 but really its up to the person… I don’t personally see it as a step above my T1.2 as after using my beyers for so long, I honestly despise the headphone much like I mnetioned I preferred the Arya over them. It’s a bit of a toss of the coin here I would recommend finding a way to try the beyers just to be sure… the purchase price does not mean they are better by any means as sound differs from person to person…
I can’t really recommend much more in that regard… 800S, arya, 1990, T1, etc all are in their own little grey area for competitive gaming… they are at the top of the board as far as performance for gaming.
