2.0 speaker for PC with no AMP, 100€
Hi
I am going to buy a 2.0 set of speakers for use with my PC.
I don’t currently have any audio gear (DACs, AMPs etc.) so I need it to work directly with the PC and nothing else. I am not currently looking to buy an AMP, but I am considering to do that in future (I also have DT880s).
I stumbled upon Edifier R1280T without any prior research, so I don’t really know if it’s worth it or not (please tell). Any kind of recommendation and advise is welcome. My budget is 100€ and I don’t really want to go higher than that, because I will be still mostly using headphones and just want some acceptably sounding speakers for some occasions.
Thanks
Presonus Eris E3.5 may work for you. Just run them directly from your mainboard.
i have the r2000 and they sound more than decend for the price in near field and i didnt read much negativ comments about other Edifier products except the 900 series
so all in all i dont think youll do much wrong with it but maybe someone here has direct experience with it?
and didnt require the presonus a dac ?
Like I said, I would run them directly from the motherboards output.
But yes, they would need a source of analog signal.
Question is if @Africsnail has decided on speakers.
Yeah.
I went with Edifier R1280DBs
