2.5 mm balanced cable question
Im currently looking to buy a 2.5 mm balanced cable for my 58x jubilee and came across an eBay seller but I’m not completely sure if it’s compatible.
If not, any other recommendations?
It claims to be compatible (600, 650, 58X, all the same), but aftermarket connectors vary in quality and may be too tight or too loose a fit. I’ve got two Periapt cables for 600 series, one is good if a touch looser but the other is a very tight fit.
I got mine(for 58x and 660s 1m and 1,2m) from oidio sound uk - very good quality - friendly contact and fast shipping
you can choose between various lenghts and materials
starts at 33 pounds plus shipping but you can choose fancy colours and materials and get easy over 90 pounds or something
https://oidiosound.co.uk/
