yeah, 2 pin has a positive and negative side. The positive side usually has a dot or dent or some kind of indicator like that.
Another way to tell is with the driver/nozzle facing away from you and pins facing up, Right IEM = Right Pin Positive, Left IEM = Left Pin Positive.
