2 questions Is this safe for my HD6xx and
I have “Sennhieser hd6xx Headphones” and a “S.M.S.L M3 dac/amp” i want to run it with a" LOXJIE P20 Balance Tube Amp" (via rca) so my 2 questions are (1 will it all work together ?) (2 if i turn the volume up all the way on a p20 amp will it blow my hd6xx ?) (DAC: Link )(AMP: Link ) Thanks :slight_smile:
It should work together just fine, although I wouldn’t suggest maxing the volume on everything and have some way to control volume lol
ok thanks so turning it to max will blow them ?
It will most likely not be safe to listen to, but I don’t think the p20 is powerful enough to blow them up. It would also depend on your digital volume as well, and assuming you have it maxed, you still most likely won’t blow them up
ok thanks i just wanted to know if maxed everything up "by accident
" that when i play music they don’t explode so thanks :slight_smile:
Yeah they might distort or get to really uncomfortable levels but I highly doubt they would blow up
The P20 doesn’t have the power to blow up the 6XX.
Formating tip:
Link
[Link](hifiguides.com)
@M0N hey is this the same as the amazon listing for this items “like its not a fake ?” because its £20 cheaper on aliexpress link aliexpress amazon link “If anyone else knows please let me know”
Oh lol, i would never turn up the volume of something unless it’s not audible. I saw hd 6xx, i comment.
That still most likely going to be legit, typically ordering direct from China is cheaper
