I highly recommend the Fiio Q1. Had one with my hifiman 4XX and it sounded great, the bass switch can be addictive and it also gives you the option to run balanced one day. If you have any questions hit me up.
Hello, yes i have some questions about amp conectors, (im new to the amps)
If i had a amp that has 3 conectors 1 for power and 2 rcas (left and right) i could just get a adaptor for rca to 3.5 and plug into my pc?
Correct! 3.5mm to rca cable so you can connect to your phone as well!
Ok thank you.
You saved me 1 day of headache.
HE400se is great value. can’t go wrong with either of them imho. the HE400se is just more neutral and cleaner sounding than he4xx/he400i i would say. that is not a plus or a minus. just a type of coloring. and don’t think they are a lesser version because of the price. only their cable and packaging is inferior. and all these planar headphones can be EQed very easily. you can add insane bass and it will stay clean. lots of fun to play around with.
