~250€ Turntable recommendation
Oh ok I’m sorry I thought that you were saying that there’s a problem.
Nope there shouldn’t be any lol
Second Imput well become helpful with a Turntable in the Future. Maybe use the Second output for a nice headphone amplifier later on?
As far as I know the Mackie will convert unbalanced to balanced. A short run of unbalanced cabel from the DAC to the Mackie won’t hurt but unbalanced speaker wires could pickup some noise when getting routed next to Mains Power or a Computer.
Hmmm I don’t think this is the case since it’s a passive device, it will run unbalanced over balanced cabling.
That’s exactly what I thought.
And as for the Mackie it says on the back of it that it’s balanced or unbalanced. I guess it depends on what goes in.
Yes it will take either unbalanced TS 1/4 inch or balanced TRS 1/4 inch. If the incoming signal is balanced then the outgoing will be balanced as well. I would say get 1/4 inch TRS cables so you can still run them unbalanced for now but go balanced easily without re cabling in the future
THX…
You might be right… it isn’t converting but he should still go with TRS
Gosh we went from Vinyl to THX in 4 days lol.
What’s that ?
He is just saying thanks lol?
Ohmboy’s comment seems out of place and I just thought he’s refering to something else like certifications or whatever. You recommended the Topping E30. Can I get that and skip the Big Knob passive ? It apparently has a remote control.
I think you could do that just fine, just be careful with the volume lol
what do you mean? :))
Just make sure to not accidentally max it or something lol
