I just purchased a Sendy Apollo. The included 3.5mm plug is too small for the standard amp socket. Any suggestions?
which amp? it’s probably 6.35mm, if the amp/headphone didn’t come with a snap/screw on adapter there are cheap ones on amazon etc
Thanks. I’m using a Schitt Magni Heresy as my amp. It accepts a normal 6.35 MM plug such as the one that came with my Rode NTH-100. I swapped the 6.35MM plug from my Rode NTH-100 phones to use on my Sendy Appollo. The 3.5 MM Sendy plug is too small for the Rode 6.35 plug.
Are you sure it’s 3.5mm and not 2.5 you got on this cable? How many black stripes do you have on the plug?2 or 3?
Problem fixed. I did not know that the amp plug comes in multiple versions. I swapped plugs and all is well. The Sendy Apollo is a magnificent headphone.
