Hi guys, I’m currently looking for a 4.4 balanced for my headphone the he400i and just wondering if you guys had any recommendation as I could only find one seller for it which is this one and I’m not sure if this one is good enough. I’m also in Australia as well if that helps.
found that exact same cable here
ali express has some great cables and are a decent sourcel for your budget though you can definitely get some custom cables. there are a lot of great custom cable makers on facebook for example musikable based in the philipines. or in the US periapt through their website though i am unnaware if they do 4.4mm
Thanks for the info, just wondering if you are aware if there’s any custom cable maker in Australia as well?
i haven’t seen much i would do some googling.
You could see what shipping would look like coming from HAC.
Is that a shipping company or a custom cable one?
They make custom cables. @brux is the one who makes them.
Thanks, I will give them a try.
Hello there I was In the same boat as you when I bought my HiFIman headphones and if zen dac. Then I found hart audio cables and had them make me a custom cable that terminates into 4.4 pentaconn and its a custom length and color too you should check them out im happy with my cable
Thanks for your input, unfortunate after checking the site out the shipping rate is already almost the price of the cable so I don’t think I will get it.
Oh wait, after checking the actual stock cable on hifiman they charge 130usd for the cable so I might get HAC now haha. Oh wait, after checking the actual stock cable on hifiman they charge 130usd for the cable so I might get HAC now haha. If you don’t mind me asking, can you tell me how much was the price for your custom made one?
Hello again I am from the United States and I paid 80$ including shipping for my cable. It is a 12ft purple and green 3.5mm to 4.4 pentaconn cable im going to buy another one from them soon
Great, thank you very much. The price seems pretty even for custom cable.
