4.4mm male to 4.4mm female right-angle or L for DAP
I’m looking for the above and have found a couple but they’re both heavy and way too robust for DAP pocket use.
Anyone found something like the ddHifi converters? Seems they only change from one to another, no extension.
TIA
penon has a L shape impedence adapter which is the only L shape 4.4 to 4.4 I’ve seen.
it’s heavier than a DDhifi 6.35 → 3.5 adapter though, similar to 6.35 to 4.4
Thanks. I’ve found a number of them but I have no reason to make my amps work harder than necessary. They are never 100% even attenuation across the audible band.
Looks like I’m best off just buying the Dunu series with the L integrated
