Can you use an adapter to use a 4 pin xlr headphone plug out to 2 xlr 3 pins that plug to a power amplifier? My biggest issue with monolith thx 788 is no xlr output. Wondering if I can use the front 4 pin headphone plug.
I would not suggest doing this, you would be double amping, it would work, but you would end up with too hot of a signal along with unneeded potential distortion
In theory, yes.
In practice, I would strongly recommend against doing this.
Use a pair of XLR splitters before the amp. If you need volume control, get a monitor controller like the JBL NanoPatch+
