Currently using a Topping MX3 to power the 2 Micca RB42. It gets the job done and sounds great but I can’t max out the volume sometimes and the MX3 would just shut itself off. The only reason I can think of is it doesn’t have enough power. What would be a good replacement for it with stronger output per channel?
I have been eyeing up the SMSL A8 as something to try. I think I will end up waiting to find a discrete amp using the ICEpower 125ASX2 that I don’t have to build myself.
