looking for an active crossover under $200 that can do either 24db per-ocvt./48db per-octv, bonus points for being able to set any crossover frequency using included controls. This is what I found after ADHD searching for 30 minutes:
I’m not really wanting to go through all the dsp doodads, I just want a simple crossover that doesn’t hurt the sound… although I may consider it more if I can be convinced to go through the trouble of room correction and setting up digital connections and stuff
