Adam T7V Speaker Mods(?)
Hi all,
Just wondering if anyone has tried doing any modifications on their Adam T7V’s.
Maybe some NoRez inside to damp any last bits of resonance, or upgrading crossover parts and wire.
They do sound really good currently, but I have watched enough YT videos to know most speaker companies like to cheap out on crossover parts and wire, and that upgrading them can get that last bit of performance out of them.
Thanks,
Jody
Curios to know if there would be anything to upgrade or mod.
This is probably what is there is
I think the only mod would be on the ADC PCM1862 to PCM1863, probably would win 7db with -110db at inputs but outputs are rated at the same -103db. Don’t know if it really would have an audio impact. Got to try. Clock circuit on the ADC is also maybe a low cost crystal. Worth checking markings for a better phase noise part replacement. At the PSU, got no pictures, so can’t tell if there’s any upgrade at it. I assume is a regular switching PSU.
