Sound blaster amps aren’t really that great. Instead you should get an ifi hip dac, if that’s too expensive then you should get the fiio q1 mkii
Well, I found a G6 for $99 so I was looking at getting that. I wanna stay around the $100 range for a DAC/AMP combo.
Just gonna leave this link here. Watch it: https://youtu.be/QmrkbWslcKs
Fiio q1 mkii is also 99$ and LEAGUES better
It is better on sound quality most definitely but most of its power is in that balanced port. G6 doesnt have that issue and can power the 600 ohm beyers unbalanced so difference there. Not a big fan of the g6 but it damn sure isn’t bad for $100.
