Advice on mmcx cables
Hi all,
I’m looking for a nice replacement cable for my IEMs. I was planning on getting the Tripowin C8, but then I saw the Tripowin Zonie 16-core which is €12 cheaper. Does anyone know how these two compare and if the C8 is worth €12 more?
(Zonie: https://www.amazon.de/Linsoul-Tripowin-Silver-Earphone-0-78-3-5mm-Grey/dp/B07ZQC9MZB/ref=sr_1_1?__mk_de_DE=ÅMÅŽÕÑ&keywords=tripowin%2Bzonie&qid=1583183180&sr=8-1&th=1)
(C8: https://www.amazon.de/dp/B07SS9DB16/ref=sxbs_sxwds-stvp?__mk_nl_NL=ÅMÅŽÕÑ&cv_ct_cx=linsoul%2Bc8&keywords=linsoul%2Bc8&pd_rd_i=B07SQQ4M8X&pd_rd_r=a5e4b73a-bd5b-4c00-b060-f7fccb1c109c&pd_rd_w=f3Uv6&pd_rd_wg=RGmAo&pf_rd_p=6d84c7ba-ae72-4e53-b9a4-5df18ccb370e&pf_rd_r=3GCN6CNBNW7J8MTCM31P&qid=1583183230&th=1)
16 cores sound better than 8 core, but that is purely founded on the idea that more equals more better which usually doesn’t fly when it comes to these things.
Thanks :slight_smile:
of course this will vary based on your ear/head and I do not know about the specific cables you’ve listed, but between the 8 core and 16 core (TRN) cables I have I’ve found that although the 16 core is a nicer cable it tends to hurt the top of my ear when i wear it for extended periods, I would assume because it’s heavier. Again ymmv
it depends entirely on if you atre what some in the IEM community maybe even the rest of ther audiophile community I just hear the term most in that space call cable sensitve. where you can hear the difference in cables especially if you have sensitive IEMs . my philosophy on IEM cables personally is if looks good and comes form a reputable company you should be fine. I use a zonie cable myself and its great build wise. cables are just another pitfall but one maybe worth looking into. I find that cbles matter most in the comfort department
I have no idea whether I am cable sensitive, since I’ve only tried the one that came with my FA1. The cable is decent but it has two flaws, the pre-shaped over-ear thingy is to wide, so it doesn’t properly hook behind my ear (I read at least one other person who also found this) and the cable terminates in a 90 degree end which isn’t ideal. Apparently the Zonies “Continue the highly appraised of Triowin C8”, but I wanted to check whether there wasn’t some horrible flaw someone knew about which causes this one to be cheaper than it’s “predecessor”. Are the over-ear parts shape-able and/or comfortable out-of-the-box?
I have 16 and 8 core, the 8 core feels more resilient and better made. I don’t buy 16 core anymore.
Damn you David! I was just ready to pull the trigger on the Zonies, and now you make me hesitate again.
I think I’ll be going for the Zonies still, since I am probably going to upgrade in the future to balanced cables, plus I still plan to get the Blon’s at some point so I’d also need cables for that, I don’t feel much like buying 3 $30 cables. So I’ll probably get the Zonies at least for the unbalanced 3.5mm mmcx which I will end up replacing within a year.
Also there’s a coupon, so the c8 is actually €14 more expensive, making it almost twice the cost of the Zonies.
i mean you can grab yinyoo balanced cablesfor like $10 on sale
Yeah but I don’t have any devices with balanced output yet. So the upgrade to balanced cables would include a DAC (probably btr5) as well…
Oh yeah the BTR5 is a very highly recommended bluetooth device for IEMs and headphones, or just a good amp/dac for the price too.
having no frame of reference to other like devices, I really like the BTR5 and I use it daily. Really nice device
I prefere the look and feel of the C8.
But i do have some QC issues with my Tripowin cables. My 3.5mm is fine but my 4.4mm cable has massive imbalance problems so i have to turn it back to Linsoul. Now i switched to a FiiO LC-C for 4.4mm.
Did you know this video?
Hmm I haven’t noticed any imbalance problems on my Tripowin Zonie. I used the LC-B series 4.4mm but I didn’t really like those, I much prefer the Zonie cable. Maybe I’ll go for the C8 when I need a new cable at some point.
