Affiliate Links Customized
I would suggest you make a Region select button to change your affiliate links to Amazon.co.uk , Amazon.de , Amazon.it and so on.
I would like to support HIFIGuides when i Buy something from Amazon but since I dont live in the US I cannot use your Affiliate links.
(or just add the other options but then it would get a bit overloaded in my opinion)
