AFUL Performer Eight S (P8S)
Upcoming from AFUL, Its next entry in the PERFORMER Series…
The AFUL Performer Eight S
Configuration
1DD + 6BA + 1 Passive Radiator + 1 Micro Planar Quadbrid In-Ear Monitor
From the Designer:
Faceplate Design Inspiration — Echoes of Jupiter
The swirling storms and pearl-like cloud bands captured by the Juno probe over Jupiter’s north pole sparked the designer’s imagination. The Performer 8S doesn’t try to replicate a planet but instead captures the grandeur of the cosmos, the ordered chaos of its atmosphere, and the ring-like aura that feels almost like an ancient symbol of power.
Sound Parameters
Compared to the original Performer 8, the 8S is fuller, grander, and slightly warmer. With balanced tuning across the spectrum, it delivers a stable, natural sound with a wide stage and strong resolution without harshness. Vocals are realistic yet smooth, and the bass is elastic with solid impact, outperforming rivals in its class.
Features:
The Performer Eight S offers two bass styles through its dynamic + passive setup.
A long bass tube enhances sub-bass, while a high-damping vent improves texture.
Closed: solid, atmospheric, and stable.
Open: deeper extension with a softer, more elastic character, ideal for orchestral music.
Adjustable Passive Unit + Pressure Balancing
The passive radiator includes an open/close vent, allowing users to tailor the sound to their preference or music style.
With the vent closed, the bass is more stable, solid, and controlled.
Opening it gives the bass better elasticity, deeper extension, and a smoother, softer character.
Unlike traditional switches that only change bass quantity, this vent system creates two distinctly different bass textures.
Cable
The cable features 4N single-crystal copper with silver plating plus single-crystal copper, 6-strand, 392-core construction. The 0.78mm detachable design offers excellent flexibility, allowing users to easily swap cables to suit different music styles, personal preferences, or usage scenarios.
Specifications
Brand: AFUL
Model: PERFORMER Eight S (P8S)
Impedance: 26Ω±20%
Sensitivity: 108dB@1kHz
Frequency Response: 10Hz-35kHz
Driver Configuration: 1DD+6BA+1PR+1MP
Cable Connector: 2Pin(0.78mm)
Cable Length: 1.2m
Plug Termination: 3.5mm or 4.4mm
Working Sound Pressure Level: 20~105dB
Technology:
High-Precision 3D Printed Acoustic Tube Structure
RLC Network Frequency Division Correction Technology
High-Damping Air-Pressure Balance System
Looks great. I’m excited to see what they do in the space next.
Indeed it is. I’m buying the Performer 8, so we can have a proper comparison with this one. The Sound paramaters is their pitch, obviously. We’ll find that out soon…
Yeah they are Great
