So we got a new puppy and it chewed up my akg 361 stock cable. Does anyone have a bead on a manufactured replacement with the locking 2.5mm?
Welcome to HFGF! I believe as a temporary solution you could simply get 2.5mm cable to connect it. But I will say, been looking for one to a friend of mine and so far no luck.
@brux and @CapistranoCables any of you guys make a custom cable with this termination? I’ve heard it’s a little different than the Sennheiser locking 2.5mm but I’m not sure.
Edit: Tagged Jason from Capistrano Cable wrong, sorry.
Thanks. Ill try one out I have a few 2.5mm around. I just didn’t want to jam something in there. I really appreciate it. Yes if anyone knows someone making these types of cables i would forever be a customer lol.
I tagged both of them here for convenience, but you could go to their respective stores and ask them directly.
Brux = Hart Audio Cables
Jason = Capistrano Cables on Etsy.
@brux does from HAC. It’s a custom order thing, but he does make them. I just ordered one.
Perfect, thanks guys.
