Another pair of Headphone
Okay,
So it easy to find what.
Some Adresses are in Germany,maybe the Site are nit English but youncan contact the Admin a tell him what do younneed so it make you an offer.
https://musikerkabelladen.de/epages/193bde29-123f-4693-bdf8-aa87781554bd.sf/de_DE/?ObjectPath=/Shops/193bde29-123f-4693-bdf8-aa87781554bd/Categories
Are in Germany.
https://oidiosound.co.uk/ is in England.
You only need make a Cebel withe Nighthawk conector and the 4,4 mm balance conector.
What cabel do you want you can choose and the colors too.
I hope is helpfull.
^^^ Yep JT at Oidio Sound will sort you out or you could try…
The Forza team https://forzaaudioworks.com/en/category.php?id_category=7
Ok guys. Thanks. I’ll update when I’ll get the Hiby.
Then I’ll think about the cable.
if you ask stupidly you might be able to tinker yourself into one, or maybe you know someone?
If so, it would be much cheaper.
The plugs are not as expensive as the cable.
Should only be done correctly, it is not really difficult, you just have to know which cable is what and solder clean to the contacts.
Did two for my headphones myself took a little.
