Hey everyone, I’m interested in the QKZ x HBB IEM’s for general use and was wondering if there are any replacement cables that have very good mics in them?
while it should work the connector would stick out a lot further than usual idk about anything that actually uses the qdc connection
I actually just purchased this cable about a week ago. It works well and the mic does sound much better than any inline mics. The only real issue with it is the R connector with the mic is a bit thick and won’t fit into an IEM with a recessed connector like the Moondrop Aria. It does fit well with my LETSHUOER S12
Thank you I appreciate the response, going to check this out
I have had this for a couple months and I like it but it’s not perfect. As far as cables go it’s extremely light which is great and the mic is good however the interchangeable adapter is press fit and comes undone a lot for me which is not good. Also the cable is not the best wound
