「ARTPICAL GABRIEL」: Arguably one of their most compelling earphone thus far
「ARTPICAL GABRIEL」
Arguably one of their most compelling earphone thus far…
✧ ════ •REVIEW• ════ ✧
「SOUND-SIGNATURE」
To my ears it follows the tuning of neutral with a bass boost. The bass has a tasteful amount of warmth and low-end presence. Same goes with its mid-range and vocal presentation. It sounds intimate and smooth. The treble falls along the lines of neutral, providing sufficient brightness and extension to highlight the highs. It is easy to listen and suitable for variety of music genres.
「BASS /LOW-END」
► Its bassline has this familiar boosting sensation to enhance your bass experience. While it has a prominent elevation, it sounds more like a “soft-core” than a full fledge “bass-head” set. It carries a moderate speed which is neither too fast nor sluggish. It can still linger and sustain long enough for the bass notes to fully dispersed. In spite its bassy nature, it sounds relatively clean and well-controlled.
► Though it is sub-bass oriented, it has a low bass biased to it. Meaning, when the subline drops, it doesn’t hit the deepest. But it extends low enough for you to feel it. It still proves to have good level of sustain and pressure for the bass elements to sounds atmospheric. You don’t only hear it, you can feel the low resonating rumble and underlying tremor as it slowly builds up. The subtle vibration combined with a strong densified presence give its subline elements a welcoming texture. You should be able to vibe with EDM, hip-hop and rap music without feeling much lacking.
► The low-mid bass section will sound denser and fuller in tone. But as soon as it tries to reach for upper bass region, it gets softer and lighter in density. Thankfully, the attack amplitude is still fairly wide with a note-weight that is plausible to keep percussive bass hits sounding relevant.
► Kick-drums in general hit big and punchy. It sounds authoritative with a realistic fast thudding impact.
► Drum-strike will sound less frontal in comparison, but it still managed to hit big. It gives off a slam and bonk that is taut and sturdy with believable sense of texture.
► Bass line guitar does sounds lighter in density. It doesn’t sound as evocative, but not to a point it sounds monotonous.
► Ghetto bass is not the bounciest I’ve heard, while bass-distortion effect seems to have good clarity. Bass-drop sounds most effective if falls around low bass region. If its plays around the lower sub-bass or upper bass, it gets quieter with less discernible contrast.
► Bass control is superb. Even on heavier bass tracks, it keeps it clean from mud or bloat sensation while being impactful.
“Overall, the bass performance is quite solid. I don’t feel like it is lacking in presence nor does it slack in terms of definition. It’s got decent dynamics to keep listeners engaged while keeping its basslines firm and tidy. Mind you, the low-end is not coming from a dynamic-driver setup. But the two MCP drivers did such an amazing job to imitate the physical impact of a dynamic-driver.”
「MID-RANGE /VOCAL」
► The mid-range has this warm-neutral tonality that is very smooth and pleasant to listen. The vocals and instrumentals have good sense of presence and clearness to them. The lead vocals showcased to have a wider and closer image on stage. They’re well separated from the background elements allowing vocal playback to shine through.
► While sounding remarkably clear, the level of detailing is just average to my ears. The layers of texture on vocals or instrumentals will have a smoother features. Whilst not being the most analytical of the bunch, it is not void of details. They’re just more subtly presented. Hence, any sort of harshness or sharpness is well-taken care off.
► Being smooth and easy to listen is one thing. But the tonal balance allows it to have a consistent level of note-weight and density no matter what range you’re in. Thinning or hollow effects are not an issue here, which I truly appreciate. It offers a solid fundamental body with well expressed dynamics. Such traits make its mid-range sounds rather euphonic.
► MALE/LOW-PITCHED : Male vocal performance is just pleasant to listen. They have a good, reserved energy and a vocal weight that is befitting across the range. Bass and baritone ranges sound rich and full. It can sustain strong enough to bring the best out of the chest voice. Higher male range (tenor) have a fair extension to keep up while sounding full-bodied. It is simply a soothing experience. It ensures the emotive aspect of the performance being gently delivered to keep listeners feeling connected.
► FEMALE/HIGH-PITCHED: They sounded clear with excellent vocal density (from contralto to soprano). They go for a warmer and relax presentation. The lower part of the voice seems livelier. The rise and fall to the voice becomes less discernible as it pulls higher in the range. Their performance will sound more controlled and less liberating. Some part of the breathy or airy complexion coming from those soft, delicate voices is more subdued to my ears. If you’re looking for an angelic upper mid-range vocals, then this is not it. If you’re on the other side of the camp, this will suit you very well. It can handle shouty and screamy vocals without feeling fatigue. While the vocal dynamics is on the safe side, I don’t find it to be necessarily flat or lifeless.
► There is no major tonal quirk as far as my assessment goes. There is not a hint of grainy artifacts or sharp edges on vocal transient, even on a poorly recorded track. You could expect a good level of refinement coming from it.
► Acoustic guitar will have a warmer, rounded playstyle. There is nice woody resonance upon released for added depth.
► Piano plays naturally. Though, every tap does sound a tad softer, there is still enough natural weight and expression to sound distinct.
► Violin/Cello often come by with a sweet, warm sheen that is just delightful to listen. It sounds expressive with good clarity.
“Overall, it is just a smooth, warmth, intimate and pleasurable experience that many will appreciate. I genuinely had a good time with it when I want to just chill and relax.”
「TREBLE / HIGHS」
► The treble responds in such a way that is north of neutral. It just provides enough brilliance to cater the upper registry. If you’re expecting an airy, open sounding highs. You will not be experiencing that here. It is for people who seek a natural high-end presence without feeling dark or dull.
► The treble is surprisingly smooth. It handles peaky or sibilance quirks brilliantly. It doesn’t over trimmed or dampened them to a point it become blunted. There is not a hint of spice or glare that could potentially cause slow fatigue.
► Treble definition may not be up to its A game. It prioritized a smoother presentation than being a sharp analytical beast. Those essential treble elements are well highlighted for the most. I don’t find it to be severely lacking in nuances. But it is worth pointing out that, the highs will never be that of a crunchy and crispy nature. Treble-heads will find it to be a tad too smooth. But for most people, they preferred this way.
► Hi-hats sounds slightly further back in the mix. It focuses more reproducing a clear initial attack. It can “chick” constantly without getting blurred.
► Cymbals seems to follow suit. While it’s got decent note-weight, the attack will have smoother edge. The clanging and washing of cymbals still carry a decent flowy character. The instantaneous cymbal splash does come across more dampened.
► Drum-snare sounds fast and precise. The “pops” and “cracks” showcased to have a decent depth without sounding peaky.
► E-guitar sounds clear and energetic without any glaring transient. Even on overdrive solos, it performs skillfully.
► Glockenspiel sounds weighty but it dings softly with less bell-like reverb.
► As for synth or electronics, it is highly dependent on the frequency band. The lower part of range will carry more bite and weight. While, the upper range will sound smoother and softer in transient.
► Treble sensitive folks will have nothing to worry about. It is quite a safe treble even for loud volume listeners. Due to its smooth nature, it is less ideal for monitoring purpose.
" It may not have the sharpest definition in the game (for its price-point) but the level of refinement it possesses is certainly one the best in class. Certainly more than asking price would suggest."
✧ ════ • TECHNICAL PERFORMANCE & OTHERS ASPECT • ════ ✧
The STAGE has big dimensions. It sounds wide and tall with believable sense depth to not sound flat. It will sound on the intimate side as if you’re experiencing a performance in a centre- first row seat.
IMAGING performance is just average. Spatial cues sound accurate with decent sharpness with its image projections.
INSTRUMENT SEPARATION is well executed thanks to its spaciousness. The vocals and instruments have good sense spaces between them. Even on a more complex tracks, it keeps the formation steady. Perhaps will sound closer to each other in that regards.
DETAIL-HANDLING is may not be its forte. Regardless, it has good balance of micro and macro-detail throughout the range. But the image resolution is above average, it like listening to big canvas of sound without getting any sort of pixelated sound.
TONE & TIMBRE? The tonal balance is easy to appreciate. It will run most genres just fine. It can offer a consistent level of note-weight and body. The notes have good level of sustain and decays precisely as it should. However, I do feel like that attack sound a tad too smooth for my liking. I’d appreciate a higher attack amplitude to improve the overall sound definition. As for the rest of it, it is well done.
DYNAMICS? It falls on the balanced side of the scale. It is not too energetic but it is not too laid-back either. Whilst sounding smooth, it is not void of emotions. The musical expressions are still there to keep listeners in tuned with the music.
DRIVERS? They’re well implemented. They sound very cohesive with minimal timbre contrast. It is not that hard to drive. But it does proved to scale well at louder volume and higher amplification rate.
PRICE? Having to spent time with it. This is probably one of the best price-performance value within Artpical’s line-up. At least based on what I have tested. That beautiful resin shell finish is just exquisite! It is one the few IEMs that you can still appreciate while not using it. You’re not paying the $265 for just the performance alone but also for its bespoke physical form factor. I mean just look at it.
✧ ════ •BUILD/ PACKAGING/COMFORT• ════ ✧
My lord! the golden archangel design is just stunning to look at. If you have around sub 300 bucks lying around for free. And you value artistic craftmanship more than anything else, just go right ahead and buy the Gabriel. Everyone should own this just to behold some next level of resin finish. Nobody does something quite like it. It is such remarkable piece of art. Truly it is.
However, I could see some potential fit issue. Especially, when you have smaller ears. If you’re facing this issue, do spend some time doing tip-rolling, just to get the best fitment. Once, you get the right fit and seal, it is quite a comfortable shell to be worn. It is lightweight with no weird edges to the way it shaped. It is well vented with no driver-flex issue.
It came with a simple two-core silver-plated copper cable that is quite light and comfortable to use. It’s got no issue with microphonics. It’s got an interchangeable plug with 4 pin lock mechanism (3.5MM/4.4MM/Type-C) that is useful and easy to operate. The carrying case and the stock silicon ear-tips ( 2 types, sizing from S to L) is very similar to the Raphael.
→ CONCLUSION ←
The Artpical Gabriel is simply of their best released. Especially from value standpoint. Its got the sonic performance to covers its main objective. And it came with some of the most gorgeous looking earpiece design I’ve seen in person. I am not even surprised to see people splurging to own one just for the looks alone. They said that beauty is power. And it is. Who can blame them? It is just piece of art. I adored that aspect it. It feels special even when you’re not using it. Again, the sound quality is not bad either. Yes, it is not ground-breaking in terms of performance. But given the price it competes, I doubt you will be disappointed by it. That said, I wholeheartedly recommend the Gabriel if you’re new into this the brand. You should just skip the Raphael (cheaper model) and go for the Gabriel instead. The smooth and pleasant tuning is quite safe for a blind purchase. And just by looking at that the golden archangel design makes you want to own it even more. It is undeniably attractive. Combined those aspects altogether, makes it Artpical’s best value product to date. Hands down!
2026 ARTPICAL GABRIEL
PRICE : PERFORMANCE [$265] : ★★★★⯪ (9.0/10)
BUILD & PACKAGING [BASED ON PRICE]: ★★★★ (10/10)
COMFORT : ★★★★★ (8.0/10)
PERSONAL ENJOYMENT (BIASED) : ★★★⯪ (7.0/10)
OVERALL : ★★★★ ( 8.5/10)
1-2 ★ - Appalling! please avoid this
3-4 ★★ Subpar offering, there are better options out there!
5-6 ★★★ Decent with some caveats! Not a bad pick! (CONSIDER)
7-8 ★★★★ Not perfect but solid choice! This should be in your shortlist. A nice addition to your collection. (SHORTLIST) (RECOMMENDED)
9-10 ★★★★★ One the best in class! You should go right ahead & buy one! A must have! (BLIND WORTHY)
PROS:~
  • Impressive MCP performance. Very dynamic-driver like.
  • Warm, pleasant and intimate mid-range.
  • Smooth, neutral highs.
  • Above average stage dimension.
  • Solid technical performance with high level of refinement.
  • Well implemented crossovers.
  • Scales well with volume and amplification.
  • Versatile tuning.
  • Stunning design with premium built.
  • One of Artpical’s best value to date.
CONS:~
  • Not the most resolving in its class.
  • Dynamic expression is on the safe side.
  • Potential fit issue with smaller ears.
Driver Configuration: 2MCP + 2BA + 1MCP
MSRP: $265.
DISCLAIMER
~ This unit is sent by ArtpicalOfficialARTPICALPalavox for a review.
~ Assessment took after 2-3 days of running process.
~ Running on stock 4.4MM BAL & Spinfit CP100 (M).
Where to buy? (Unaffiliate)
Thanks for reading~~~! ╮(╯▽╰)╭
