「ARTPICAL RAPHAEL」 : Amalgam of art and sound…
「ARTPICAL RAPHEAL」
Amalgam of art and sound….
✧ ════ •IN-DEPTH REVIEW• ════ ✧
「SOUND-SIGNATURE」
It has a W-shaped tuning style. On most tracks, it sounds quite well-balanced, accept for highly composed treble music, it can lean on the bright side. Vocals have good focus in the mix that sounds lively on higher octave. The bass has good sense of presence and quality to cover the low-end spectrum.
「BASS /LOW-END」
► The low-end is obviously elevated. It showcased to have good bass-shelf providing ample of bass presence without stepping into bass-head territory. It does not overwhelm the upper registry on heavier bass tracks. It is not the warm, slow, enveloping type of bass presentation. It focused more on attack, speed and control.
► Sub-bass have adequate extension. It tends to settle down in the background with adequate sense of pressure and sustain. It doesn’t linger unnecessarily as it fades in and out at a dime. The underlying rumble or seismic tremor have a subtle vibration that gently tingle your eardrums. It may not have the most atmospheric feel but one could still hear its quick resonating effect.
► The upper presence seems to have a wider attack amplitude. Perhaps, denser in mass. Again, it still moves at a relatively fast paced. It gives off a quick attack with believable sense of note-weight. Such traits allow percussive bass hits to leave for a good impact.
► Kick-drums packs a good punch. It feels fast and impactful with abit of wooliness behind its physical hits.
► Drum-strike slams hard enough with tactile feedback that sounds elastic.
► Bass line guitar has a more discreet presence. The humming and droning effect has faster tempo to it.
► Ghetto bass seems to have flatter rebound. Bass-drop rendition has a discernible contrast. Meanwhile, bass distortion paddle can be picked up if you pay closer attention.
► Bass control is well-managed. There is no sense of unwanted bloat feel or muddiness that could blur your music clarity.
“Overall, the bassline has a good balance of quality and quantity. For a fast, punchy bass, it is quite a fun listen.”
「MID-RANGE /VOCAL」
► I’d consider this to be a mid-range forward set. Vocal and instruments that live in this region were given a clear spotlight on stage. Both male and female vocalist have a rather wide image. They’ll sing closer to you as they moved forward from the background elements. The vocal positioning can vary ever so slightly depending on the mix.
► When it comes to extracting nuances from vocal texture or instrumental playback, it does it fairly smoothly. They layer of detail are well laid-out without sounding grainy or scratchy. It has good balance of euphony and clarity.
► Despite its bright leaning tonality, it still managed to provide adequate sense of warmth and body to ensure vocals and instruments to have a solid grounding. Everything is kept well densified to avoid the unnecessary hollowness or thinness.
► MALE/LOW-PITCHED : Bass range tend pushed back a little. While baritone they’re not the fullest sounding but there is still solid fundamental density behind the voice. The deeper voice tends to have a safer dynamic. It doesn’t sound as powerful as I would like. The natural rise and fall to the voice is less discernible. However, the vocalist will change its gear upon reaching for the higher octave. Tenor soars high with a melodious performance. They sing with enough drive and energy to utter every word with full enthusiasm.
► FEMALE/HIGH-PITCHED : Contralto sounds more relax with its playback. The subtle tone-shift has a flatter tune to it. Due to that, some of the emotive aspect may have been lost in the translation. However, the micro-dynamic will start to gain traction from mezzo-soprano to soprano range. The higher the vocal range, the more direct it feels with its emotional delivery. As for nit-picks, on certain occasion, the voice can lack abit of sustained tone as it fades a tad too soon before it can bloom completely. Such trait can make performance sound more restrain and less liberating. Thankfully, it didn’t sound soulless which is worth noting. On the bright side, the vocal density is more consistent here. There are no shouted vocals or screamy voices as far as I could tell. Aside from that, the sense of breathiness or airy whispers are well preserved within the mix.
► Acoustic guitar in general has a natural bite and weight when plucked, but lacking abit of overtone presence.
► Violin and cello have nice melody to them. The bowed strike sounds very expressive.
► Piano plays may not standout as much. But when you listen carefully, it sounds fairly natural.
" Whilst the mid-range were given good focused in the mix, it is not tuned to be a vocal specialist, due to its less consistent performance. In spite its weakness, I believe vocal enthusiast can still appreciate it for what it can offers. The reality is it is not bad at all."
「TREBLE / HIGHS」
► The treble is undeniably bright. But it is well-done for the most part. Most of the brightness comes from the air presence which cannot go without noticed. On certain pairings, there is a layer of haziness that tends to mask the lower spectrum. The bright lower to mid treble region does contribute to a stronger sense of treble definition.
► Despite its bright nature, the treble response is relatively smoother than most bright sets I’ve encountered. Even at louder volume, it maintains its evenness quite well. There is no unwanted resonance such as treble spikes, glare or sibilance.
► The high-end definition is one of its strengths. It can highlight the surface of treble elements quite well. If and only it had a darker, cleaner background, the treble could have been top tier. Regardless, the treble elements still come across sounding natural rather than saturated. It doesn’t sound overly crisp or weightless. There is still adequate sense of weight behind every high notes.
► Hi-hats is well presented without being too frontal. The “chick-ing” effect has natural tone behind it. It doesn’t sound fuzzy when hitting constantly at a variable rate.
► Cymbal plays seem to follow suit. It doesn’t sound overly splashy when it crashes. The underlying continuous clang has a fine texture that decays smoothly as it washes away.
► Drum-snare sounds tidy. The “pops” and “cracks” sound precise and clear. It doesn’t sound peaky when it thuds.
► Electric guitar doesn’t seem to standout above the crowd. I wish it has abit more gain to sound more distinct. It tends to blend with the crowd. In rock and metal tracks, it sounded more reserved than I’d like.
► Glockenspiel sound rather straightforward. It dings and it fades. It doesn’t linger enough to hear the harmonic overtones clearly.
► Electronic or synthesizers (ring, zing, ting, buzz and etc.) sounds effective yet refined. It doesn’t sound sharp nor aggressive.
► Treble sensitive folks might find the ultra-highs to be a little too airy. There is where ear-tip rolling is crucial. Once you get the right ear-tips, it will no longer becomes a hindrance. Thanks to its analytical nature, it is more than capable to use for monitoring purpose.
" The treble performance is not all perfect. But it is one of the better defining highs coming from a single dynamic-driver of its ilk."
✧ ════ • TECHNICAL PERFORMANCE & OTHERS ASPECT • ════ ✧
The SOUNDFIELD has decent dimensions. Though, the width is quite average, but the headroom is taller than usual with believable sense of depth.
IMAGING prowess has good balance of accuracy and sharpness to the image.
INSTRUMENT SEPARATION is solidly done. Vocals and instruments tend to sit closer to each other, but the separated elements seem to have clear cut. Even on busier tracks, the delineation of sound is well sorted.
DETAIL-RETRIEVAL is above average for its price-point. Micro-detail is well layered without sounding artificially sharp. While the macro aspect of it is no slouch.
DYNAMIC-RANGE is wide enough to be in tuned with the music. It is far from sounding laid-back but it’s not overly energetic. It sits somewhere in the middle.
TONE & TIMBRE? Tonally, I have no major qualms with it, except for the noticeable accentuation with the air presence. Due to its fast, precise nature, some of the sustained tone or reverberation feel may sound more subdued. As a result, on slower music, it can sound less organic.
DRIVER? The 10.0mm PU+LCP dynamic driver did a great job in trying to achieve this level of sound fidelity. It performs befitting of its price-point without breaking a sweat.
SYNERGY? I’ve come to noticed that it is not the easiest to drive. It does require abit more power to reach for my normal listening volume. (roughly 20-25% more power). If you’re finding the ultra-highs to be a tad too bright, it is best to pair with warmer and darker source. As for the choices of ear-tips, it is best to get a deep insertion for the best treble response.
PRICE: At $150, it performs exceedingly well. From tunings standpoint, there is no major dealbreaker while its technical performance is not lacking. It sounds solid through and through. What’s outstanding is the build. It is the most beautiful and complex resin shell finish I’ve seen. The packaging may not be as grand as Lucifer Lightbringer, but it has a complete accessory.
✧ ════ •BUILD/ PACKAGING/COMFORT• ════ ✧
The resin build is outstanding! The black and golden 3D printed wings is a piece of art to behold. The shell is around medium-small size. However, due to its unique design, I did face some fit issue with my default selection of ear-tips. I ended-up using a smaller sized ear-tips to get the best fit and comfort. There is no driver-flex or pressure build-up issue.
It came with 2-strand silver-platted copper cable. The swappable termination (3.5MM/4.4MM/Type-C) uses a 4-pin multi-lock that holds the plug tightly. Though the type C USB DAC can give it a sufficient drive, I ended up using the 4.4MM BAL for most of time to get the best experience out of it. The stock cable is slightly on the stiff side and prone to memory.
They provided us with small carrying case that should be able to fit both the earpiece and cable altogether. There 2 types of ear-tips (narrow and wider bore) sizing from S to L, arranged in a tiny transparent case. It is well packaged and well accessorized.
→ CONCLUSION ←
The Raphael may seem like an affordable offering coming from Artpical, but in terms of build, it doesn’t lose out to its bigger brother the Lucifer Lightbringer. However, due to its price limitation, the sonic performance is not going to be as good as the Lucifer Lightbringer which is to be expected. Having said that, the Raphael is quite well tuned as it is. It is not perfect, but it does the job well. I didn’t like the Raphael initially due to its fit and airy highs. But after getting the right synergy and few days of running in, it changes my mind completely. I am enjoying more than I ever did. It grows on me the more I listen to it. Which is a good sign. With that said, if you’re looking for a beautifully made earphone that is quite fun to listen to. And you can’t afford the Lucifer series, the Rapheal is set that you should be considering. It is genuinely a good product for what it is trying to be. It can be a brilliant option for a gift too.
2026 ARTPICAL RAPHAEL
PRICE : PERFORMANCE [$150] : ★★★★ (9.0/10)
BUILD & PACKAGING [BASED ON PRICE]: ★★★★★ (10/10)
COMFORT : ★★★★ (8.0/10)
PERSONAL ENJOYMENT (BIASED) : ★★★⯪ (7.0/10)
OVERALL : ★★★★ ( 8.5/10)
1-2 ★ - Appalling! please avoid this
3-4 ★★ Subpar offering, there are better options out there!
5-6 ★★★ Decent with some caveats! Not a bad pick! (CONSIDER)
7-8 ★★★★ Not perfect but solid choice! This should be in your shortlist. A nice addition to your collection. (SHORTLIST) (RECOMMENDED)
9-10 ★★★★★ One the best in class! You should go right ahead & buy one! A must have! (BLIND WORTHY)
PROS:
  • Ample of bass presence that feels punchy and controlled.
  • Lively upper-range mid-range, forward vocals.
  • Well-defined highs.
  • Solid technical chops.
  • Gorgeously build.
  • Well accessorized.
  • Good overall value.
CONS:
  • Need a bit of tip-roll to get the best fit.
  • Ultra highs can be abit too airy for some tracks.
  • Vocal performance can be lacking in certain areas.
Driver Configuration: 10MM PU+LCP Dynamic-Driver
MSRP: $150.00
DISCLAIMER
~ This unit is sent by Artpical for a review.
~ Assessment took after 5-7 days of running process.
~ Running on stock 4.4MM BAL & No-brand narrow bore (S)
BIG THANKS TO ArtpicalOfficial
Thanks for reading ╮(╯▽╰)╭
Where to buy? (Unaffiliate) :
