Asking a weird question: Memory Foam tips
What’s the difference between ‘dekoni audio’ foam tips, and regular foam tips made from china? There’s a big difference in the price of these, and wanted to know if it was worth picking up.
I’ve got some regular made in china foam tips, they are soft and better than silicone tips which are generally harder and rigid. However, they still warm up my ears and i cannot immerse myself in music truly. So i’m wondering whether i should get better tips, aka get dekoni tips which Z likes a lot.
The dekoni tips are quick rebound, so you don’t really have to roll the tips compared to like comply. It really depends on the tip tho
Oh what is tip rolling? The ones i have take like a few seconds to get back into shape.
I mean where you kinda have to keep squishing it to get it in your ear, like memory phone
Thanks. So i mean, is there no solution for end goal tips xD I think that’s why i’ll tend to like headphones way more. Just for the comfort itself.
Different tips will change the sound depending on the iem, so it really depends lol. I typically prefer the sound of silicone tips but that’s just me
Foam tips do absolutely nothing for me, I have Dekoni, Xcessor and Kz and apart from comfort and soundstage they all murder the bass. On the other hand silicone tips do work very well, with these you can tell the difference between cheap and expensive, density and form of the eartip affect very noticeable the sound of the Iem, treble bass miss and soundstage change and every Iem works different with every eartip. A hassle,I know. I’ve spent around 100 euros in tips and lots of hours changing them in my various iems. In the end is a try and error thing, be brave, prepare your wallet and good luck! :wink:
