Hello.I’ve been using atom amp and hd58x on my setup.But i decided to go for elex,since i decided to get an elex i thought i need an amp upgrade.Which amp to pair with focal elex? Is it a worth to upgrading archel 2.5+ enog 2 from atom+d10 ? Geshelli stack is little bit above my budget but i can stretch if im missing too much clarity detail or fun.
Geshelli stack sounds like a nice step up but if you think the atom and d10 sounds fine and and an upgrade may hinder you financially don’t bother upgrading
Personally I think you should wait and save until you can get a more substantial upgrade imo. The g stack would be an upgrade, but not a very large one imo, the atom + d10 is already very solid
I agree with @RiceGuru and @M0N , the Geshelli stack is quality gear, no doubt, but the Atom and D10 also punch above their weight. The improvement from Atom+D10 to Geshelli stack probably isn’t worth the immediate upgrade. Bide your time and save your money for something in the next tier up.
Next tier for Elex would be something like A3/B2 or RNHP/B2?
I would say something like an rnhp or burson soloist mk2, the bifrost 2 is also nice but I would prioritize the amp first
Thanks for quick reply guys, im already happy with my stack and i guess i couldn’t get massive upgrade around this price bracket.then i’ll wait
I’d hold off. You are in a pretty good spot right now. I second what others are saying. No rush, you’re getting a very good use of the elex from the Atom
