Zeos has weird ears and with love affair with the NDH20’s makes me think he likes restricted dynamic drivers a ton. Sometimes you have have to think people had different ears + preferences.
As far as the RNHP comments, I find DACs make substantial a difference.
Well Zeos loves the Sendy Aiva too. He seems to like a large vareity of sound signatures. he also loves things that are different. Unique. Thats essential to know when you watch his videos. If he reviews something thats the standard headphone or amp hes like “meh, its ok…” Thats probably why he doesnt like reviewing DACS so much lol.
He also doesnt like diminishing returns. expensive audio equipment when you can get so close to it with cheaper gear. He likes detail but not when it interferes with enjoyment of music. He’s mainly about the music
Ok Burning in the russian tube for 24 hours. and no more noise. but WOW. BIG difference in sound. Sounds great! This is almost rivaling the RNHP if not just out right beating it. and the Arya doesnt sound that bad in it. Aren’t planars bad for otl tube amps?
Ok i just cant get over the change in this thing. The stock tubes must have been junk! Funny cause they look identical. The Auteur now sound more full than the Arya. Which now sounds more unatural and less body. so crazy. I think i love tube amps!
I also notice that i dont have to turn the volume up that high. The tube seems to have given it more volume if im not mistaken. Is it possible it gave it more detail too?
I would seriously consider it. ZMF headphones seem to take to them very well. But i recommend a hybrid if youve got other headphones that wont take to it. I really wish i could hear my Arya in these. also the russian tube 6H8C. its sounds awesome and cheap at 10$
Lyr 3 is on my list with the tube from the Dark Voice. I don’t know if hybrids really get the same tube sound but screw it, I have to make some sacrifices because I can’t handle the heat most of the time in the summer with my other electronics.
Auteurs are on my list but M0N mentioned the Eikons and made a good argument. The Ziricote are in my shopping cart right now. 5 more days before I pull the trigger.
They don’t give the same sound, but personally I do like the extra punch from the solid state on the eikons. Also the lyr 3 still gets really hot lol (also consider the liquid platinum as well)
I could use my darkvoice as a preamp for my RNHP right? just use the output RCA’s to the RNHP input? is that right? Then i could get some tube action on my Arya? Would it make that big a difference? Or should i just get a hybrid tube amp?
