First time seeing this ones, similarly priced although different material diagrams is what the difference in price is I guess. Gonna be interesting to see the difference in sound with the different diagram materials. Just saw some new 1DD from Tangzu with diamond coating diagram or something like that and costs quite much.
Actually not, most oems dont charge you more to change diaphragms from one to another if its the same model.
Diamon-Like-Carbon, maybe?
(DLC)
Apparently I guess advanced version of DLC:
”At the heart of the TANGZU LI ZHI lies a 10mm dynamic driver featuring a genuine diamond crystal evaporated diaphragm, achieving 40% greater rigidity than traditional DLC coatings. This virtually eliminates split vibrations, enabling extraordinary resolution and transient speed. The result is an effortless full-range response that delivers thunderous dynamics and delicate micro-detail with uncompromising clarity.”
This is from the product page, this was released couple of days ago. I remember getting notification for post from Tangzu somewhere on the socials.
He went up using only green hand holds because I said “green”
I didn’t mean ONLY green but he did it
He’ll be 3. 1/2 June 24.
His mother came in so I asked him to do again
He picked up the ball and 1 handed the easy route
I gave him a muted compliment and he got pissed
He really does not want to be told what to do
This is why Wrestling is going to help him
Noice
11/10 (i was gonna put 10/10 for char there
Sounds like marketing fluff. Pretty sure almost all diaphragms are coated via evaporation method…
LLM for reference that also agrees.
Yea probably marketing gimmick, seemed like that to me. Although the asking price ain’t small for this set for 1DD configuration, but if it delivers in the sound department I guess it is fine. Never had anything from Tangzu other than mine Wan’er 2 regular edition.
Bruh 1 mf driver just died, outta nowhere, never took it out the shell, only had wires connected to the terminals replaced, never touched more than 1~2secs, the dual unit interconnect wires were untouched, so just to make sure i rechecked by soldering wires and connecting them in parallel to the main driver, but nope, driver is dead. Outta nowhere, like tf just happened…? ![]()
i told the guy that things could get destroyed in the process, but the aim was to retain the mids driver, so that was never touched except for the wires resoldering part ![]()
i’m gonna get labelled as incompetent… FML
Right vs Left Mids…
Edit: the guy either getting my KE4 for his replacement, or I’m seeing this through with another mids/low treble driver
That’s a RAB32063 from Knowles, ig Moondrop’s Magic is in the Tube.
Good Morning Y’all,
I had a Perfect Replacement with ED29689, This BA is a solid replacement and even louder for than a dual unit.
Shall be back on track by tomorrow ![]()
perfectly follows variations in treble, but meta cut at 1.5k, peak back to 2.8k instead of 3.2~3.5 on the MD BA, and more low mids/low-end.
Its a Huge W. Also better 8k might I add ![]()
10 characters
Don’t sweep the leg (mids are life).
Never seen kites like that, they’re pretty cool ![]()
Thanks. Time for you to make a thread ![]()
I’m interested in family, politics and sometimes audio.
I’ll be checking in on your new thread
Good luck ![]()
Its up, will be posting stuff here regularly, Thanks ![]()
Your post motivated me ![]()
I wanted to have a steak sandwich but can’t heat the vegetables
Cooked the steak ![]()
Wrapped with cheese and sauce
Air fryer
Took a second wrap and put the baked one inside that with lettuce tomatoes and onions
Bingo
Pretty much no carbs and tasted amazing
Got to try that, it looks delicious!
Inspired by your work.
I double wrap and lay it so only 3/4 is doubled up with 1/4th extending it so I can get a wider roll.
Makes my dieting a whole lot more enjoyable.
Tuna avacado melt is next
Youtube rec’d me this vid
Someday it will be done about IEM/Headphones.
The chapter about expensive multi thousand dollar sets not sharing internal components won’t be believed by 99.9% of the viewers
That looks amazing.
I gotta up my game
