Lessons learned from tuning and reviewing but mostly tuning.
Estat can take more input but also can be tuned a bit lower than BA and DD
BA’s are often cited as being just alright for bass. I’d argue they are mostly weak in treble.
Timbre…grainy. Tonality, inauthentic
I don’t have much experience in the matter, but aren’t ba the best Thing we have for mids?
It’s a subjective matter, IMO. I strongly prefer the tonality of DD mids, for example. BA’s can sound “plastic’y” sometimes. YMMV
I would like to find out how a small DD would perform in the mids.
I think you can get a very clean sound by putting BAs in the “mud frequencies”.
Hey Chris I have a question hanging around, I understand that a hybrid/trybid IEM is tuned via component selection and adjusting the crossover board making thinks towork together in a way, but how do you tune a DD?, I mean, the small differences between Olina and O2, being the same driver, how are obtained? is there some kind of circuit inside a DD?TIA
In this post there is basic answer from great Oratory1990 on what affects the final sound in typical DD headphone :slight_smile:
I am sure HBB would give more insights from his perspective, however based on the fact that Olina uses O2 driver as a base not many things could be adjusted in it itself but in acoustic chamber around mostly
Great info! Thanx.
DD drivers are like tiny versions of home speakers and are tuned by the enclosure (volume/material) mostly, though you can alter the driver by changing material behind the polepiece or in front
the 02 driver did not work in the Mele shell. It worked pretty much perfect in a Mele body with a new nozzle and the driver at a tiny angle.
@hawaiibadboy How do the Tea and Tea 2 compare size- and shape-wise?
TEA 2 is a little bit bigger like a clair shell but a bit smaller but same design
@hawaiibadboy Would you say the Tea 2 is a direct upgrade to the original Tea or more of a sidegrade?
Direct upgrade. I think it sounds better across the board (Bass to mid to treb)
:eyes: :eyes: :eyes:
Me trying to calm myself waiting for the review:
This is kinda scary sounding to me because of QC…I hope they don’t just slap that driver in place.
No the inside of the shell is machined aluminum and it was cut at several angles till the right angle was found and that was mass produced :+1:
That gets rid of all concerns about driver placement…:+1:t3:
Mike Bruce of Short Bus spent a good while taking apart mele and driver.
It is an absolute tank build
Olina is same. The “Seat” for the driver to sit in is machined into body.
@hawaiibadboy check inbox please. It’s regarding Olina :slight_smile:
Thanks
Somebody hold me. Finally, new Sony DAPs? DAC/AMPs? IEMs? Headphones? It’s been so long..
Dang I wish I could be in the big bois club :joy::joy:
